January 5, 2023, 13:43 |
Stupid question about velocity
Alan w
Rep Power: 6 |
Since I have been working with OpenFOAM for a while, I should understand this question. But it seems I don't.
Regarding the motorbike tutorial, when I run it and then view the results in paraView, in the Mesh Regions, I only visualize the motorbike and the ground. In other words, I un-check the internal mesh. In the boundary conditions for U, the motorBikeGroup is set to noSlip, and the lowerWall is set to fixedValue, internalField. My understanding of boundary layer flow is that adjacent to the surface, the velocity is zero for a noSlip condition. So in paraView, when viewing the results for U, I expect to see the motorBike colored blue, indicating zero flow velocity, and the ground colored according to the flow velocity. But, as can be seen in the attached image, there is color variation on the motorBike as if the flow was moving along the surface; for example, the flow speeds up over curved areas. But with noSlip, shouldn't it be zero all along the motorBike surfaces? I'm sure there is a simple answer that I am missing, but I would love to see see it. |
January 7, 2023, 09:41 |
matej forman
Rep Power: 17 |
Do not worry, it is a ParaView thing. The way how the values are represented. At the top, second Toolbar - you may select a variable to plot. Typically there are two velocities. One with an orange cube. Those are raw data - cell centered. The other ones with an orange dot are interpolated values. Raw data will show velocity calculated by wall function thus it is not zero. Hope it helps.
January 13, 2023, 12:54 |
Thank you, Matejfor
Alan w
Rep Power: 6 |
Thanks for your reply! I looked at both of your suggested approaches, but still don't see a graphical depiction of zero U at the wall in paraView. This bothers me, as I thought I saw an Air Shaper video that showed what I am looking for.
Inlet velocity profile question | dmirel | STAR-CCM+ | 4 | October 8, 2019 05:42 |
VELOCITY vs VELOCITY IN STN FRAME vs RELATIVE VELOCITY | everest20 | FLUENT | 1 | July 13, 2015 09:35 |
Question Regarding to Export and Import The Velocity Profile | John Lee | STAR-CCM+ | 4 | September 19, 2014 10:01 |
Perhaps a stupid question... | HSeldon | FLUENT | 0 | March 9, 2007 13:14 |
stupid question | Andrew Hayes | Main CFD Forum | 9 | December 20, 2005 12:25 |
