Could pressure gradient be modelled as "vectorCodedSource" in fvoptions at inlet
Old   January 3, 2023, 16:28
Default Could pressure gradient be modelled as "vectorCodedSource" in fvoptions at inlet
chandra shekhar pant
chandra shekhar pant is on a distinguished road
Dear Foamers,
I am trying to see the effect of time varying effect of pressure gradient on the periodic channel in OpenFOAM v1906, thus wondering if, it is correct to use the
vectorCodedSource
at the inlet volume by creating a cellzone using inlet area \times deltax (streamwise direction resolution) in topoSetDict. If that is somehow mimicking the actual pressure gradient then I have following questions:
1. What should be the value of deltax for defining the cellzone in topoSetDict
2. What should be the magnitude of this source term in the
USource[celli] += vector(?, 0,0 )
should it be the exact value of dp/dx or something different.
Any comment/suggestion would be very much appreciated, many thanks in advance.
chandra shekhar pant is offline   Reply With Quote
Old   January 14, 2023, 09:21
Hello All,
I guess I figured this out, so the basic principle is that the fully developed channel means that it's kind of steady state and the pressure gradient force is exactly balanced by the wall shear stress. So the body force to be applied inside the fvOptions is the magnitude of dpdx, now there are 2 questions:
1. Where should this force be applied and how?
2. What is the magnitude of this force and how it should be incorporated in the fvoptions?
Answers to the questions
1. Using topoSetDict create cellzone as:
/*--------------------------------*- C++ -*--------------------------------
actions
/// for creating volumetric force
        name 	source1;
        type	cellSet;
        action	new;
        source	boxToCell;
        box     (0 0 0) (Lx Ly Lz);
        name    source1;
        type    cellZoneSet;
        action  new;
        source  setToCellZone;
        sourceInfo
            set source1;
After creating this zone, check if this is what is been expected using paraview:
1.
foamToVTK -cellSet source1
2. ParaFoam should be opened in the main case file
3. Through the existing opened paraFoam file, open the VTK and open the source1.vtk file on the top of the previous opened file so that we can see both the whole domain and the zone where we intend to apply the force.
2. For applying the body force using:
codedSource
    type            vectorCodedSource;
    selectionMode   cellZone;
    cellZone        source1;
    fields          (U);
    name            codedSource;
	// modified to include the pressure wave
	codeAddSup
 forAll(cellsZone,i)
        		const label celli = cellsZone[i];
        		USource[celli] -= vector(dpdx*V[celli], 0, 0 );
    codeCorrect
    codeConstrain
    code
            $codeInclude
            $codeCorrect
            $codeAddSup
            $codeConstrain
Then I checked the results from this procedure against the utility vectorSemiImplicitSource in fvoptions using:
pressureGradient
    type 		vectorSemiImplicitSource;
    selectionMode   all;
   volumeMode specific;
    injectionRateSuSp
   U ((dpdx 0 0) 0);
and got the exact answers.
Wind tunnel Boundary Conditions in Fluent metmet FLUENT 6 October 30, 2019 13:23
pimpleFoam in OF1612 shows same time step twice in log file shang OpenFOAM Bugs 10 January 24, 2018 11:43
pisoFOAM (LES) - internal pipe flow - convergence gu1 OpenFOAM Running, Solving & CFD 0 January 11, 2018 17:39
Pressure Inlet: question about total pressure I-mech FLUENT 0 July 13, 2014 06:38
help with boundary profile in pressure inlet quiqui FLUENT 21 June 18, 2013 13:55
