Steady or transient which is faster to get thermal steady status |
January 1, 2023, 11:02 |
Rep Power: 4 |
Hi all,
I want to ask steady or transient which is faster to get thermal steady status. My simulating object is a heater which is in a container. Gas flows through the container from an inlet and an outlet. The heating power of the heating unit in the heater is controled according to temperature of a point in the heater. The aim of adjusting heating power is to keep the temperature-monitored point in the heater around the target temperature. After the whole system, i.e. the heater and the flow around the heater, reaches thermal steady status, the uniformity of temperature distribution at the top surface of heater is to be checked. I have shallow knowledge on CFD and know in steady analysis there is no accelerating item in the equation but do not know its effect on speed to reach steady status. My knowledge cannot answer steady or transient which is faster to get steady. Could anybody give explanation on this? Thank you very much! Currently I have tried chtMultiRegionSimpleFoam. ChtMultiRegionFoam has not been tried. |
January 3, 2023, 03:24 |
Rep Power: 5 |
If you only need a final state of your system, then a steady solver is usually the way to go, although you might want to look into pseudotransient solvers. They can be more stable depending on the kind of flow (buoyancy and natural convection for instance) and helped me quite a lot. But you should first try to use chtMultiRegionSimpleFoam for sure
heat transfer conefficients as boundary data for transient thermal simulations | TharunSK | CFX | 2 | April 2, 2019 03:09 |
FSI Transient Thermal Analysis | Abduri | CFX | 1 | January 1, 2017 22:54 |
Transient & steady simulation | DIVYA P SOMAN | ANSYS | 0 | September 3, 2016 14:09 |
Transient Thermal Stress Distribution | Ijaz | CFX | 0 | February 19, 2009 16:27 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
