thermophysicalProperties with polynomial value for viscosity
Old   December 26, 2022, 11:51
Default thermophysicalProperties with polynomial value for viscosity
mch2
usermch2 is on a distinguished road
I am using rhoSimpleFoam to simulate the flow between two coencentric cylinders with the outer one rotating. My simulation for constant viscosity went well.
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "constant";
    object      thermophysicalProperties;
thermoType
    type            heRhoThermo;
    mixture         pureMixture;
    transport       const;
    thermo          eConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleInternalEnergy;
mixture
 specie
        nmoles          1;
        molWeight       18;
    thermodynamics
        Cp              4180;
        Hf              0;
        Cv              4150;
    equationOfState
       rho             1000;
    transport
        mu              0.1;
        Pr              7.56;
When I set the polynomial values for viscosity my simulaion is not converging. I tried setting muCoeffs<8> (0.1 0 0 0 0 0 0 0) to see if it will converge but didn't.
My thermophysicalProperties file:
thermoType
    type            heRhoThermo;
    transport       polynomial;
    thermo          hPolynomial;
    equationOfState icoPolynomial;
    specie          specie;
mixture
specie
        nmoles          1;
        molWeight       18;
    equationOfState
        rhoCoeffs<8>    ( 1000 0 0 0 0 0 0 0 );
    thermodynamics
         Hf              0;
         Sf              0;
         CpCoeffs<8>     ( 4200 0 0 0 0 0 0 0 );
    transport
         muCoeffs<8>     ( 0.275  0.0080882353  0.0000108131  0.0000000064 0 0 0 0 );
         kappaCoeffs<8>  ( 0.598 0 0 0 0 0 0 0 );
T file:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      T;
dimensions      [0 0 0 1 0 0 0];
internalField   uniform 350;
boundaryField
    innercylinder
        type            fixedValue;
        value           uniform 340;
    outercylinder
        type            fixedValue;
        value           uniform 350;
    top
		type empty;
    bottom
		type empty;
U file:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    innercylinder
          type noSlip;
    outercylinder
        type            rotatingWallVelocity;
        origin          ( 0 0 0 );
        axis            ( 0 0 1 );
        omega           4; // rad/s
    top
		type empty;
    bottom
		type empty;
fvsolution:
solvers
    p
        solver          GAMG;
        smoother        FDIC;
	maxIter		10;
        tolerance       1e-6;
        relTol          0.0001;
    "(U|e|k|epsilon)"
        solver          GAMG;
        smoother        DILU;
cacheAgglomeration      yes;
nCellsInCoarsestLevel   60;
nPreSweeps              0;
maxPreSweeps            2;
nPostSweeps             2;
maxPostSweeps           2;
nFinestSweeps           2;
	maxIter 	50;
        tolerance       1e-8;
        relTol          0;
SIMPLE
    nNonOrthogonalCorrectors 0;
    pMin      1;
    pMax      1.5;
	pRefCell 0;
    transonic       no;
    consistent      no;
	pRefValue 1e5;
    residualControl
        p               1e-4;
        U               1e-6;
	e		1e-6;
        "(k|omega|epsilon|h)" 1e-8;
relaxationFactors
    fields
        p               0.8;
    equations
        U               0.6;
        e               0.8;
        k               0.8;
        epsilon         0.8;
Could someone help me or give hint? I really woul appreciate it.
usermch2 is offline   Reply With Quote
Fluent UDF - polynomial profile description mihnea333 FLUENT 0 February 26, 2021 04:19
Error: GENERAL CAR CDR - User-Defined-Material-Database EvaKn FLUENT 0 December 21, 2020 09:01
Add piecewise polinomial material property EvaKn FLUENT 0 December 21, 2020 07:03
thermophysicalProperties with polynomial values Gerrit OpenFOAM Running, Solving & CFD 4 April 21, 2020 11:51
polynomial BC from 3d vector data map OpenFOAM Programming & Development 0 March 30, 2015 09:48
