icoFoam, pisoFoam, pimpleFoam unsuccessful transient solution of laminar flow channel |
December 24, 2022, 12:13 |
Andrew gow
Rep Power: 3 |
Hi, I have modelled a small contraction-expansion micro-channel and get steady state laminar flow solutions (via SimpleFoam) for a range of fluids.
I want to check how the laminar flow develops into the steady state, so want to model it via a transient solver. I have tried icoFoam, pisoFoam and pimpleFoam but consistently get 'nan' residuals. Example below (laminar shear-thinning fluid flow using pisoFoam, with very very small timestep as I wanted to check that the Courant number was ok): Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model powerLaw Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Time = 1e-12 Courant Number mean: 1.78444e-12 max: 1.69643e-10 smoothSolver: Solving for Ux, Initial residual = 1, Final residual = 0.125661, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.000204169, Final residual = 4.28595e-05, No Iterations 1 GAMG: Solving for p, Initial residual = 1, Final residual = 1.27784, No Iterations 1000 GAMG: Solving for p, Initial residual = 0.00590419, Final residual = 0.00283648, No Iterations 1000 time step continuity errors : sum local = 2.19094e-12, global = -7.73091e-14, cumulative = -7.73091e-14 GAMG: Solving for p, Initial residual = 0.0081096, Final residual = 0.0042503, No Iterations 1000 GAMG: Solving for p, Initial residual = 0.0802758, Final residual = 0.0285281, No Iterations 1000 time step continuity errors : sum local = 1.18382e-12, global = -4.21001e-14, cumulative = -1.19409e-13 GAMG: Solving for p, Initial residual = 0.181867, Final residual = 0.0826181, No Iterations 1000 GAMG: Solving for p, Initial residual = 0.13259, Final residual = 0.0732679, No Iterations 1000 time step continuity errors : sum local = 1.37441e-12, global = -4.97442e-14, cumulative = -1.69153e-13 ExecutionTime = 39.502 s ClockTime = 40 s Time = 2e-12 Courant Number mean: 1.88248e-09 max: 3.55571e-07 smoothSolver: Solving for Ux, Initial residual = 0.999071, Final residual = 0.723957, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.998321, Final residual = 0.0997865, No Iterations 412 GAMG: Solving for p, Initial residual = 0.992996, Final residual = 0.0988467, No Iterations 472 GAMG: Solving for p, Initial residual = 0.0426151, Final residual = 0.0042522, No Iterations 658 time step continuity errors : sum local = 2.3776e-09, global = 2.28602e-11, cumulative = 2.2691e-11 GAMG: Solving for p, Initial residual = 0.622031, Final residual = 0.0620596, No Iterations 404 GAMG: Solving for p, Initial residual = 0.141261, Final residual = 0.0140427, No Iterations 638 time step continuity errors : sum local = 2.31854e-09, global = -2.2299e-11, cumulative = 3.92025e-13 GAMG: Solving for p, Initial residual = 0.294358, Final residual = 0.0291968, No Iterations 340 GAMG: Solving for p, Initial residual = 0.0368593, Final residual = 0.00103414, No Iterations 1000 time step continuity errors : sum local = 1.02061e-10, global = -9.67482e-13, cumulative = -5.75458e-13 ExecutionTime = 63.389 s ClockTime = 64 s Time = 3e-12 Courant Number mean: 2.78448e-06 max: 0.000431458 smoothSolver: Solving for Ux, Initial residual = 0.920662, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = 0.899158, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 time step continuity errors : sum local = nan, global = nan, cumulative = nan GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 time step continuity errors : sum local = nan, global = nan, cumulative = nan GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 time step continuity errors : sum local = nan, global = nan, cumulative = nan ExecutionTime = 104.086 s ClockTime = 105 s Time = 4e-12 Courant Number mean: nan max: nan smoothSolver: Solving for Ux, Initial residual = nan, Final residual = nan, No Iterations 1000 smoothSolver: Solving for Uy, Initial residual = nan, Final residual = nan, No Iterations 1000 GAMG: Solving for p, Initial residual = nan, Final residual = nan, No Iterations 1000 My fvSolution file is: solvers { p { solver GAMG; tolerance 1e-4; relTol 0.1; smoother GaussSeidel; } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-4; relTol 0.1; } pFinal { $p; relTol 0; } UFinal { $p; relTol 0; } } PISO { nCorrectors 3; nNonOrthogonalCorrectors 1; pRefCell 0; pRefValue 0; } } relaxationFactors { equations { U 0.9; ".*" 0.8; } } My controlDict file is: application pisoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 0.5; deltaT 0.000000000001; writeControl runTime; writeInterval 0.1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; Does anybody have an tips? I get the same problem ('nan') with all transient solvers. Thanks |
Open channel flow with PisoFoam | kraf | OpenFOAM Running, Solving & CFD | 1 | November 3, 2021 02:47 |
Open channel flow with PisoFoam | kraf | OpenFOAM Running, Solving & CFD | 0 | October 14, 2021 01:46 |
Validation: Turbulent Channel Flow, pisoFoam, LES | Xiaoyu Yang | OpenFOAM Running, Solving & CFD | 23 | December 19, 2019 12:51 |
Enabling Open Channel Flow Sub-Model in Mixture model | cod213 | FLUENT | 0 | January 10, 2017 14:40 |
Simulating a Laminar Isothermal Flow in a 2D rectangular Channel | HectorRedal | Main CFD Forum | 1 | December 18, 2016 12:41 |
