heat source by semiImplicitSource does not take effect if radiation model is open ?
Old   December 20, 2022, 05:46
Default heat source by semiImplicitSource does not take effect if radiation model is open ?
hogglife is on a distinguished road
Hi all,
For a chtMultiRegion problem, if I turn on the radiation, can I meanwhile set inner heat source by semiImplicitSource in fvOptions ?
In a case I performed, the inner heat source set by semiImplicitSource does not take effect if I turn on the radiation. After I turn off the radiation and change the boundary condition to "compressible::turbulentTemperatureCoupledBaffleMi xed", the inner heat source takes effect.
Does anyone know if it is a limitation of OpenFoam?
I am using openFOAM v2206.
Thank you in advance!
hogglife is offline   Reply With Quote
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[swak4Foam] groovyBC in openFOAM-2.0 for parabolic velocity bc ofslcm OpenFOAM Community Contributions 25 March 6, 2017 11:03
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 Seroga OpenFOAM Community Contributions 9 June 12, 2015 18:18
[swak4Foam] Swak4FOAM 0.2.3 / OF2.2.x installation error FerdiFuchs OpenFOAM Community Contributions 27 April 16, 2014 16:14
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 02:24
