Weird result using overset mesh
Old   December 20, 2022, 00:03
Default Weird result using overset mesh
Longbow85 is on a distinguished road
Hi guys,
I am a newbie to openFoam. I am trying to simulate a flapping foil in 2D using the overset meshing.
The domain size is 30x10, and the foil is eclosed by moving grids of size 3x2. The BC is a freestream from left to right. The solver I'm using is overPimpleDyMFoam and the mesh kinematic is given by tabulated6DoFMotion. However, the solution is bit weird. The flow seems being confined in the moving grid only, and is not propagating into the background mesh. Please see the attached video.
Any comments or suggestions are greatly appreciated. Thanks!
Longbow85 is offline   Reply With Quote
Old   January 13, 2023, 06:48
Karim Ahmed
Karim ahmed is on a distinguished road
can you provide the fv scheme dict and fv solver ? to check
Karim ahmed is offline   Reply With Quote
Old   February 17, 2024, 20:18
SeaFD is on a distinguished road
Probably a bit late, but might be useful for anyone else with the same problem.
I had the same thing occurring and found the problem.
In the dynamicMeshDict the dynamicFvMesh should be set to dynamicOversetFvMesh whereas I had it set to dynamicMotionSolverFvMesh.
SeaFD is offline   Reply With Quote
Old   September 19, 2024, 06:47
Shen Tsao Hung
santhou is on a distinguished road
same as the problom
santhou is offline   Reply With Quote
Old   October 8, 2024, 07:45
Default Flux Corrections to be added
Skill-Lync CFD
CFD_with_Skill-Lync is on a distinguished road
HI,
From what I can see, flux correction iterations needs to be added in dynamicMeshDict and fvSolution files. Please let me know if you require help with the syntax!
Thanks
Skill-Lync
CFD_with_Skill-Lync is offline   Reply With Quote
Overset mesh for Fluid Structure Interaction in OpenFOAM Thaw Tar OpenFOAM Programming & Development 4 August 25, 2023 18:56
[snappyHexMesh] SnappyHexMesh/splitMeshRegion : region1 in zone "-1" GuiMagyar OpenFOAM Meshing & Mesh Conversion 3 August 4, 2023 13:38
foam-extend-4.1 release hjasak OpenFOAM Announcements from Other Sources 19 July 16, 2021 06:02
[ANSYS Meshing] 3D rotating wind turbine using overset mesh Paku ANSYS Meshing & Geometry 0 September 11, 2019 00:18
