Problems when using extend-foam IBM to simulate helix rotating
Old   December 19, 2022, 04:47
Default Problems when using extend-foam IBM to simulate helix rotating
Yateng Qiao
YatengQ is on a distinguished road
Hi everyone,
I'm going to simulation a 3D helix rotating in the fluid domain by using IBM in foam-extend 4.1.
I used movingCylinderInChannelIcoFine case for reference, but in the Z direction the mesh cell is set to be 1 in blockMeshDict. When I set 100 cells in Z direction. The error appears in the log.potentialFoam as follows:
Create mesh for time = 0
153
154
155
156 --> FOAM FATAL ERROR:
157 Error in point ordering: mixed used and unused points at the end of point list.158 Last used point: 0 (-0.02 -0.02 0.005)
159 First unused point: 1 (-0.0198667 -0.02 0.005)
160 and point 1 (-0.0198667 -0.02 0.005) is used by a live face.
161 Face 0 4(1 302 60803 60502) with points 4((-0.0198667 -0.02 0.005) (-0.0198667
162 Done.
163
164 From function void polyMesh::initMesh()
165 in file meshes/polyMesh/polyMeshInitMesh.C at line 166.
166
167 FOAM aborting
I'm not sure if the IBM in foam-extend can simulate the 3D case. I am struggled with this error for several days.
YatengQ is offline   Reply With Quote
[Other] refineWallLayer Error Yuby OpenFOAM Meshing & Mesh Conversion 2 November 11, 2021 12:04
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
[CGNS] CGNS converters available mbeaudoin OpenFOAM Meshing & Mesh Conversion 137 December 14, 2018 05:20
is internalField(U) equivalent to zeroGradient? immortality OpenFOAM Running, Solving & CFD 7 March 29, 2013 02:27
Problem with rhoSimpleFoam matteo_gautero OpenFOAM Running, Solving & CFD 0 February 28, 2008 07:51
