OpenFOAM windows mingw version cannot iterate |
December 15, 2022, 15:12 |
H. C.
Rep Power: 4 |
Thank you for reading! I installed "OpenFOAM-v2206-windows-mingw" from openfoam.com. After setting up my run folder, I tried a case. The "decomposePar" seems fine. However, when I tried "mpiexec", the error message is like: Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field "(k|epsilon|omega|f|v2)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model BirdCarreau Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Time = 1 job aborted: [ranks] message [0] process exited without calling finalize [1-9] terminated ---- error analysis ----- [0] on W simpleFoam ended prematurely and may have crashed. exit code 3 ---- error analysis ----- I then input simpleFoam directly and it showed: it showed: Create time Create mesh for time = 0 SIMPLE: convergence criteria field p tolerance 1e-05 field U tolerance 1e-05 field "(k|epsilon|omega|f|v2)" tolerance 0.001 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model BirdCarreau Selecting turbulence model type laminar Selecting laminar stress model Stokes No MRF models present No finite volume options present Starting time loop Time = 1 Could anyone please help me by telling me what went wrong? Thank you so much! |
OpenFOAM version switch from ESI to Foundation | vronti | OpenFOAM | 1 | May 2, 2022 04:48 |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 15:24 |
Suggestion for a new sub-forum at OpenFOAM's Forum | wyldckat | Site Help, Feedback & Discussions | 20 | October 28, 2014 10:04 |
CFX11 + Fortran compiler ? | Mohan | CFX | 20 | March 30, 2011 19:56 |
OpenFOAM (Linux) in a MS-HPC-Cloud | fossy | OpenFOAM | 6 | September 23, 2010 12:48 |
