CHT with radiation, inner fluid region shows unphysical behavior
Old   December 9, 2022, 07:20
Default CHT with radiation, inner fluid region shows unphysical behavior
Eren
ErenC is on a distinguished road
Hello again dear CFD nerds!
I have a CHT case with radiation (external beam, or solar load) it is basically:
Outer region (fluid), middle region (solid), and inner region (fluid). I want to calculate the irradiation inside the inner region. Top picture shows the outer region, and bottom picture shows the inner region. I think there is a problem with my middle region BCs. Because outer region and inner region G fields are not really in agreement. (outside region field shows an expected behavior, walls are reflective and top is transparent). Middle region is transparent, but I realised solver does not even reads the boundaryradiation file in middle(solid) region!
So what should be the appropriate BC to correctly calculate irradiation inside the inner region? Any help willbe appreciated!
ErenC is offline   Reply With Quote
How I can introduce my power heat (W) in chtMultiRegionFoam? aminem OpenFOAM Pre-Processing 32 August 29, 2019 03:23
Radiation in semi-transparent media with surface-to-surface model? mpeppels CFX 11 August 22, 2019 08:30
fluid fluid radiation properties IronLyon CFX 5 March 18, 2019 17:40
p_rgh initial residual no change with different settings manuc OpenFOAM Running, Solving & CFD 3 June 26, 2018 16:53
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
