December 1, 2022, 06:11 |
heat capacity in TEqn
Rep Power: 4 |
Can anyone provide some insight on this: VoF solvers weigh some properties as: Whislt the heat capacity appears to be different. Why is not being weighted as : And then: In the laplacian term appears to be treated as : What is the rationale here? I need to weigh the inverse of since that is how the formulation is derived? For instance, If I removed density from inside the parenthesis and diveded every term in the equation with , I would need to use the same treatment as ? |
Continuity Equation for multicomponent simulation | lordluan | CFX | 15 | May 19, 2020 19:36 |
heat capacity function | Red Ember | CFX | 1 | February 9, 2016 06:36 |
Heat capacity of species | atoof | OpenFOAM Programming & Development | 4 | September 15, 2014 13:31 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 08:00 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 21:11 |
