pimpleFoam residual increase in final iteration |
December 1, 2022, 04:03 |
Ahmed Hafez
Rep Power: 8 |
Hello foamers,
I try to simulate flow around a cylinder using pimpleFoam and kOmegaSST model. I set the residual control to 1e-6 for all variables and turn turbOnFinalIterOnly to false to correct turbulence in every iteration. The issue is that as you can see the residual generally increase for p in the final iteration, as compared with the previous ones. p initial residual at iteration 15 = 2.76799e-06 p initial residual at iteration 16 = 1.851e-06 p initial residual at iteration 17 = 1.25194e-06 p initial residual at iteration 18 = 8.59642e-07 p initial residual at iteration 19 = 0.000184078 Does anyone have an idea why this happens? Code:
PIMPLE: iteration 15 smoothSolver: Solving for Ux, Initial residual = 2.75291e-08, Final residual = 2.24998e-11, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 5.35638e-08, Final residual = 6.11208e-11, No Iterations 1 GAMG: Solving for p, Initial residual = 0.000341863, Final residual = 2.37683e-07, No Iterations 9 GAMG: Solving for p, Initial residual = 3.95414e-06, Final residual = 6.59996e-09, No Iterations 13 time step continuity errors : sum local = 6.0944e-14, global = 5.61034e-15, cumulative = -1.08138e-09 GAMG: Solving for p, Initial residual = 0.000239169, Final residual = 1.64455e-07, No Iterations 9 GAMG: Solving for p, Initial residual = 2.76799e-06, Final residual = 7.47063e-09, No Iterations 11 time step continuity errors : sum local = 6.89837e-14, global = 6.11525e-15, cumulative = -1.08137e-09 smoothSolver: Solving for omega, Initial residual = 9.76609e-09, Final residual = 9.76609e-09, No Iterations 0 smoothSolver: Solving for k, Initial residual = 4.70179e-09, Final residual = 4.70179e-09, No Iterations 0 PIMPLE: iteration 16 smoothSolver: Solving for Ux, Initial residual = 1.73465e-08, Final residual = 1.37002e-11, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 3.46011e-08, Final residual = 3.73245e-11, No Iterations 1 GAMG: Solving for p, Initial residual = 0.000233972, Final residual = 1.56529e-07, No Iterations 9 GAMG: Solving for p, Initial residual = 2.6403e-06, Final residual = 7.97251e-09, No Iterations 11 time step continuity errors : sum local = 7.36173e-14, global = 6.4906e-15, cumulative = -1.08137e-09 GAMG: Solving for p, Initial residual = 0.000163756, Final residual = 1.09107e-07, No Iterations 9 GAMG: Solving for p, Initial residual = 1.851e-06, Final residual = 9.65293e-09, No Iterations 9 time step continuity errors : sum local = 8.91343e-14, global = 7.90999e-15, cumulative = -1.08136e-09 smoothSolver: Solving for omega, Initial residual = 9.76794e-09, Final residual = 9.76794e-09, No Iterations 0 smoothSolver: Solving for k, Initial residual = 4.78525e-09, Final residual = 4.78525e-09, No Iterations 0 PIMPLE: iteration 17 smoothSolver: Solving for Ux, Initial residual = 1.09831e-08, Final residual = 8.19114e-12, No Iterations 1 smoothSolver: Solving for Uy, Initial residual = 2.23768e-08, Final residual = 2.14394e-11, No Iterations 1 GAMG: Solving for p, Initial residual = 0.000160724, Final residual = 1.06995e-07, No Iterations 9 GAMG: Solving for p, Initial residual = 1.78211e-06, Final residual = 9.79957e-09, No Iterations 9 time step continuity errors : sum local = 9.04879e-14, global = 7.90542e-15, cumulative = -1.08135e-09 GAMG: Solving for p, Initial residual = 0.000112516, Final residual = 7.48168e-08, No Iterations 9 GAMG: Solving for p, Initial residual = 1.25194e-06, Final residual = 6.99889e-09, No Iterations 9 time step continuity errors : sum local = 6.46267e-14, global = 5.6232e-15, cumulative = -1.08135e-09 smoothSolver: Solving for omega, Initial residual = 9.769e-09, Final residual = 9.769e-09, No Iterations 0 smoothSolver: Solving for k, Initial residual = 4.83968e-09, Final residual = 4.83968e-09, No Iterations 0 PIMPLE: iteration 18 smoothSolver: Solving for Ux, Initial residual = 7.00153e-09, Final residual = 7.00153e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 1.45239e-08, Final residual = 1.21031e-11, No Iterations 1 GAMG: Solving for p, Initial residual = 0.000110597, Final residual = 7.40441e-08, No Iterations 9 GAMG: Solving for p, Initial residual = 1.21414e-06, Final residual = 6.73644e-09, No Iterations 9 time step continuity errors : sum local = 6.22032e-14, global = 5.38254e-15, cumulative = -1.08134e-09 GAMG: Solving for p, Initial residual = 7.74651e-05, Final residual = 5.18999e-08, No Iterations 9 GAMG: Solving for p, Initial residual = 8.59642e-07, Final residual = 7.5714e-09, No Iterations 7 time step continuity errors : sum local = 6.9913e-14, global = 8.17829e-15, cumulative = -1.08133e-09 smoothSolver: Solving for omega, Initial residual = 9.76963e-09, Final residual = 9.76963e-09, No Iterations 0 smoothSolver: Solving for k, Initial residual = 4.87472e-09, Final residual = 4.87472e-09, No Iterations 0 PIMPLE: iteration 19 smoothSolver: Solving for Ux, Initial residual = 6.63675e-09, Final residual = 6.63675e-09, No Iterations 0 smoothSolver: Solving for Uy, Initial residual = 1.44178e-08, Final residual = 2.26225e-11, No Iterations 1 GAMG: Solving for p, Initial residual = 0.111005, Final residual = 9.15593e-05, No Iterations 10 GAMG: Solving for p, Initial residual = 0.00170707, Final residual = 1.29047e-06, No Iterations 24 time step continuity errors : sum local = 1.46577e-11, global = -1.53446e-12, cumulative = -1.08287e-09 GAMG: Solving for p, Initial residual = 0.00682859, Final residual = 6.35587e-06, No Iterations 11 GAMG: Solving for p, Initial residual = 0.000184078, Final residual = 9.50223e-09, No Iterations 30 time step continuity errors : sum local = 1.08533e-13, global = -1.11373e-14, cumulative = -1.08288e-09 smoothSolver: Solving for omega, Initial residual = 2.54325e-08, Final residual = 3.38142e-09, No Iterations 1 smoothSolver: Solving for k, Initial residual = 4.09102e-07, Final residual = 2.37969e-09, No Iterations 1 PIMPLE: converged in 19 iterations ExecutionTime = 251702 s ClockTime = 253133 s |
#0 prinStack(Foam::Ostream&)sh:1 addr2lin: not found addr2line failed | jerrry51 | OpenFOAM Running, Solving & CFD | 0 | September 2, 2022 15:33 |
Floating point exception error | lpz_michele | OpenFOAM Running, Solving & CFD | 53 | October 19, 2015 03:50 |
Cannot run the code properly: very large time step continuity error | crst15 | OpenFOAM Running, Solving & CFD | 9 | December 14, 2014 19:17 |
Compressor Simulation using rhoPimpleDyMFoam | Jetfire | OpenFOAM Running, Solving & CFD | 107 | December 9, 2014 14:38 |
Orifice Plate with a fully developed flow - Problems with convergence | jonmec | OpenFOAM Running, Solving & CFD | 3 | July 28, 2011 06:24 |
