Approach for replacing filter for simulation
Old   November 30, 2022, 15:53
Default Approach for replacing filter for simulation
Emil Kammer Hansen
nymand94 is on a distinguished road
Hello
I am simulating the flow through a hvac system.
To start off I am using simpleFoam, laminar for simplicity. I intend to add turbulence later on, when things are running.
The problem:
In the HVAC system, there is a filter, which I know the pressure drop across, as a function of massflow.
I want to simplify the simulation as much as possible. I am considering 3 different approaches.
Option 1:
Remove filter from the simulation entirely, and link the the patches of the inlet and outlet, using cyclic, cyclicAMI or fan constraints
Option 2:
Pretty much the same as option 1, though using the more recently released NCC - Any advice of pro/cons for either is appriciated.
Option 3:
Simulate the filter as a porouse region. converting the whole simulation to porouseSimpleFoam, ballparking the values of the DarcyForchheimer coeffs.
I have a attached a picture of the situation. please let me know if i need to clarify anything.
Any advice is appreciated. - Do I need to consider any 4th option? NCC vs AMI
nymand94 is offline   Reply With Quote
Old   December 1, 2022, 04:28
Yann
Yann will become famous soon enoughYann will become famous soon enough
I would go for the 3rd option. No need to switch solver, you can use porous zones in simpleFoam thanks to the explicitPorositySource in fvOptions (or fvModels)
If you have the pressure drop of your filter function of velocity you can compute the Darcy-Forchheimer coefficients.
Regards,
Yann
Yann is offline   Reply With Quote
Old   December 1, 2022, 05:58
Emil Kammer Hansen
Thank you for the advise.
Do you know if it is possible to have a region with a specified pressure loss? I found the fanPressure patch, but I think a pressure loss/gain region would be better in my instance.
Else I would use the patch internally at the outlet of the filter
Old   December 1, 2022, 07:23
Yann
For any source term applied to a zone inside the mesh, I would say fvOptions/fvModels is the way to go. You can have a look at the different sources available but explicitPorositySource seems to be appropriate.
If you prefer to set the pressure drop on a patch you might find jump conditions such as fixedJump.
Yann
dynLagrangian SGS model tidal_Tom OpenFOAM Running, Solving & CFD 43 November 16, 2022 06:13
Large Eddy Simulation Nijanthan FLUENT 14 May 3, 2021 16:32
Accumulating Dust on a Filter Cartridge WalterW CFX 21 May 26, 2020 07:23
how can use the LES filter? (laplace filter and anistropic filter) ethan oh OpenFOAM Running, Solving & CFD 11 December 26, 2018 03:37
LES Filter in Smagorinsky model on inhomogenous grids Ivan Main CFD Forum 1 October 25, 2012 12:30
