selecting free stream velocity for drag and lift coefficients in ABL
Old   November 28, 2022, 11:26
Default selecting free stream velocity for drag and lift coefficients in ABL
blobuin is on a distinguished road
Hello!
I have a question, I could not find an answer to in this forum or googling. As I am rather a beginner, I cannot wrap my head around it. It might be very easy to the experts.
I have an object placed in an atmospheric boundary layer (ABL) for which I would like to calculate the lift and drag coefficients using openFoam. The ABL is defined by a reference velocity Uref at a height Zref. Zref is significantly higher up than the object. The object is located at a height where there is a high velocity gradient in the ABL.
The forceCoeffs function in openFoam has a magUInf parameter specifying the free stream velocity. However in the described situation it is unclear to me which magUInf I should set:
Possibilities for selecting the free stream velocity magUInf:
(1) magUInf = u(z_min)
(2) magUInf = u((z_min+z_max)/2) =u(z_center)
(3) magUInf = u(z_inc) //at incident height
(4) magUInf = u(z_max)
(5) magUInf = Uref
(6) magUInf = something else
It would be great to get an answer here!
Thank you all!
blobuin is offline   Reply With Quote
Calculation of lift and drag coefficients on airfoil CoolHersheys OpenFOAM Post-Processing 5 September 27, 2021 07:04
drag and lift coefficients in axisymmetric and 3D simulations! CFD-Lover OpenFOAM Running, Solving & CFD 0 July 1, 2017 17:33
Get inlet flow angle for computing lift and drag coefficients Jack001 OpenFOAM Running, Solving & CFD 0 October 30, 2015 16:25
Drag & lift coefficients for a velocity inlet BC tsi07 FLUENT 4 May 30, 2012 09:59
Terrible Mistake In Fluid Dynamics History Abhi Main CFD Forum 12 July 8, 2002 10:11
