cannot find parcel injection cell
Old   November 28, 2022, 03:38
Default cannot find parcel injection cell
xinyu
lliyuu is on a distinguished road
I'm doing a simulation of pulverized coal combustion in a furnace.I use coalChemistryFoam of openfoam8.
There is no problem when I use the predecessor's mesh. When I use the mesh I redraw, the problem of "cannot find part injection cell, paecel position=(0 0 0)" arises. I use patchInjection.
I checked the mesh. The mesh includes unusedpoints and upperTriangularFace. I used Fluent Meshing to draw the mesh. I don't know what the problem is? How can I solve this problem?
Thank you very much.
lliyuu is offline   Reply With Quote
Old   November 29, 2022, 06:59
alainislas's Avatar
Alain Islas
alainislas is on a distinguished road
Please note that from the log (picture 1) the problem is not due to the patchInjection of the coal. All submodels are OK.
The problem is with the manualInjection of the limestone, which I don't know if you necessarily need this injection? Please open the Paraview and plot the point (0 0 0), check whether this point lies within your domain or not. Otherwise change the location or disable the limestone injection if you don't really need it.
alainislas is offline   Reply With Quote
Old   November 29, 2022, 21:59
xinyu
Thank you for your help. You are right. I was too careless. I didn't modify limestone positions because I didn't need it.
Thanks again.
Lagrangian Solvers: Parcel Injection Error stamufa OpenFOAM Running, Solving & CFD 1 May 12, 2019 17:45
Fluent UDF wrong number of cells in parallel - correct in serial dralexpe Fluent UDF and Scheme Programming 7 May 17, 2018 09:26
How to find the flux through each cell in a each boundary patch? Hale OpenFOAM Pre-Processing 0 September 13, 2013 09:52
injection problem Mark New FLUENT 0 August 4, 2013 02:30
Warning 097- AB Siemens 6 November 15, 2004 05:41
