Floating point error when trying to simulate 300 million particles MPPICFoam |
November 23, 2022, 04:20 |
Josh Williams
Rep Power: 5 |
We are using cloud computing to investigate the effects of two-way and four-way coupling with high masses of small particles (between 1 and 10 micron). I have ran a case with 100 million particles (diameter, dp = 10 micron). When increasing to 300 million, the simulation cannot initialise and I get a floating point error as shown below. Has anyone encountered this before? I am using patchInjection model with MPPICFoam solver. I assume it is linked to this post on precision issue when creating very large meshes (something we also want to do). Code:
Constructing kinematicCloud kinematicCloud Constructing particle forces Selecting particle force WenYuDrag Selecting particle force gravity Constructing cloud functions Selecting cloud function outletExiting of type patchPostProcessing Constructing particle injection models Creating injector: model1 Selecting injection model patchInjection Constructing 3-D injection Choosing nParticle to be a fixed value, massTotal variable now does not determine anything. #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib64/libc.so.6" #3 Foam::PatchInjection<Foam::KinematicCloud<Foam::Cloud<Foam::MPPICParcel<Foam::KinematicParcel<Foam::particle> > > > >::PatchInjection(Foam::dictionary const&, Foam::KinematicCloud<Foam::Cloud<Foam::MPPICParcel<Foam::KinematicParcel<Foam::particle> > > >&, Foam::word const&) at ??:? #4 Foam::InjectionModel<Foam::KinematicCloud<Foam::Cloud<Foam::MPPICParcel<Foam::KinematicParcel<Foam::particle> > > > >::adddictionaryConstructorToTable<Foam::PatchInjection<Foam::KinematicCloud<Foam::Cloud<Foam::MPPICParcel<Foam::KinematicParcel<Foam::particle> > > > > >::New(Foam::dictionary const&, Foam::KinematicCloud<Foam::Cloud<Foam::MPPICParcel<Foam::KinematicParcel<Foam::particle> > > >&, Foam::word const&) at ??:? #5 ? at ??:? #6 ? at ??:? #7 ? at ??:? #8 ? at ??:? #9 ? at ??:? #10 __libc_start_main in "/lib64/libc.so.6" #11 ? at ??:? Floating point exception (core dumped) Code:
injectionModels { model1 { type patchInjection; parcelBasisType fixed; patchName inlet; nParticle 1; parcelsPerSecond 30.0e8; SOI 0; massTotal 0.0; U0 (0 0 0); duration 0.1; flowRateProfile constant 1; sizeDistribution { type fixedValue; fixedValueDistribution { value 10.0e-6; } } } } |
December 5, 2022, 05:22 |
Josh Williams
Rep Power: 5 |
FYI, we managed to fix this by setting "export WM_ARCH_OPTION=64" in etc/bashrc and etc/cshrc, and compiling from scratch.
mppicfoam |
Floating point exception from twoPhaseEulerFoam | openfoammaofnepo | OpenFOAM Running, Solving & CFD | 1 | March 19, 2016 14:56 |
[snappyHexMesh] How to define to right point for locationInMesh | Mirage12 | OpenFOAM Meshing & Mesh Conversion | 7 | March 13, 2016 15:07 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 10:53 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 04:44 |
Track/pulse particles - floating point error | John | FLUENT | 1 | September 5, 2005 10:22 |
