Foam Fatal error
Old   November 22, 2022, 04:33
Default Foam Fatal error
harshavardhan
harsha002 is on a distinguished road
I am running a DPM simulation, where I am injecting spray using hollow cone method. The simulation is performed for 12sec. I could see that the simulation has completed 12sec time period, but throwing an error file as shown below. I would like to understand if there is an error in the simulation.
Loading OpenFOAM/2112
Loading requirement: openmpi/4.1.2
[gadi-cpu-clx-2477:434319] *** An error occurred in MPI_Recv
[gadi-cpu-clx-2477:434319] *** reported by process [2433810433,4]
[gadi-cpu-clx-2477:434319] *** on communicator MPI_COMM_WORLD
[gadi-cpu-clx-2477:434319] *** MPI_ERR_TRUNCATE: message truncated
[gadi-cpu-clx-2477:434319] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort,
[gadi-cpu-clx-2477:434319] *** and potentially your MPI job)
[gadi-cpu-clx-2477.gadi.nci.org.au:434305] PMIX ERROR: UNREACHABLE in file /jobfs/35197837.gadi-pbs/0/openmpi/4.1.2/source/openmpi-4.1.2/opal/mca/pmix/pmix3x/pmix/src/server/pmix_server.c at line 2198
MPI_ABORT was invoked on rank 0 in communicator MPI_COMM_WORLD
with errorcode 1.
NOTE: invoking MPI_ABORT causes Open MPI to kill all MPI processes.
You may or may not see output from other processes, depending on
exactly when Open MPI kills them.
[0]
[0]
[0] --> FOAM FATAL IO ERROR: (openfoam-2112)
[0] Bad token - could not get fileName
[0]
[0] file: stream at line 0.
[0]
[0] From Foam::Istream& Foam:perator>>(Foam::Istream&, Foam::fileName&)
[0] in file primitives/strings/fileName/fileNameIO.C at line 69.
[0]
FOAM parallel run exiting
[0]
[gadi-cpu-clx-2477.gadi.nci.org.au:434305] 6 more processes have sent help message help-mpi-errors.txt / mpi_errors_are_fatal
[gadi-cpu-clx-2477.gadi.nci.org.au:434305] Set MCA parameter "orte_base_help_aggregate" to 0 to see all help / error messages
harsha002 is offline   Reply With Quote
cfd air pollutants, foam fatal io error, openfoam
[OpenFOAM] ParaView command in Foam-extend-4.1 mitu_94 ParaView 0 March 4, 2021 14:46
Mesquite - Adaptive mesh refinement / coarsening? philippose OpenFOAM Running, Solving & CFD 94 January 27, 2016 10:40
Compiling dynamicTopoFvMesh for OpenFOAM 2.1.x Saxwax OpenFOAM Installation 25 November 29, 2013 06:34
checking the system setup and Qt version vivek070176 OpenFOAM Installation 22 June 1, 2010 13:34
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
