add a passive scalar to my simulation
Old   November 20, 2022, 16:00
Post add a passive scalar to my simulation
Amirreza
arezayan87 is on a distinguished road
I need to add as pollution source in my domain. I want to to do it by using a passiveScalar. then I used a scalerTransport class in controlDict:
HTML Code:
functions
pollution
    type            scalarTransport;
    libs            ("libsolverFunctionObjects.so");
    // Optional entries
    // Name of scalar field to transport, default = 's'
    field           s;
    // Name of flux field, default = 'phi'
    phi             phi;
    // Name of density field for compressible cases, default = 'rho'
    rho             rho;
    // Name of phase field to constrain scalar to, default = 'none'
    phase           none;
    // Set the scalar to zero on start/re-start
    resetOnStartUp  no;
    // Name of field to use when looking up schemes from fvSchemes
    // default = <field>
    schemesField    s;
    // Diffusivity
    // Fixed value diffusivity
    D  0.0000176;
    // Name of field to use as diffusivity, default = 'none'
    nut             nut;
    // Run-time selectable sources
the problem is OpenFoam shows a fatal error:
HTML Code:
[I]keyword diffusion is undefined in dictionary [/I].
my solver is simpleFoam
arezayan87 is offline   Reply With Quote
Old   November 21, 2022, 13:24
Krapf is on a distinguished road
My guess is that you are using OpenFOAM from openfoam.org but the definitionen of the function object is for OpenFOAM from openfoam.com. Here you can see the explanation for the missing diffusion keyword: https://cpp.openfoam.org/v10/classFo...t.html#details (There it is written "diffusivity entry", but it should be "diffusion entry".)
Krapf is online now   Reply With Quote
Old   November 24, 2022, 05:40
Default it's Done!
Amirreza
Thanks a million,
your guess was right I corrected my code and it's done.
functionobjects, scalartransport, simplefoam
Add scalar "shift" to an already computed simulation jcoelho5 OpenFOAM Programming & Development 1 September 13, 2022 20:00
whats the cause of error? immortality OpenFOAM Running, Solving & CFD 13 March 24, 2021 08:15
Passive Scalar for particulate contamination spread Owen2612 Main CFD Forum 0 January 3, 2020 07:15
Is it possible add a passive scalar to an already finished simulation? anon_q OpenFOAM 8 April 3, 2018 04:06
Add passive scalar temperature equation to the Channelflow YANGLIANG OpenFOAM Running, Solving & CFD 1 March 9, 2010 06:23
