parallel run does nto restart correctly
Old   November 16, 2022, 16:42
Default parallel run does nto restart correctly
Michael@UW is on a distinguished road
OpenFOAM v2106:
I have the following controlDict and run in parallel.
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         50;
deltaT          0.001;
writeControl    runTime;
writeInterval   1;
After it finishes at t=50s, I modify the endTime to 60, but it does not continue. I found there is a system/controlDict in each processor folder, and it just read the controlDict in the processor folders so the change in the case/system/controlDict has no effect.
So I have to do the following:
1. change the endTime in case/system/controlDict
2. reconstructPar -latestTime
3. decomposePar -latestTime -force
4. mpirun -np 4 pimpleFoam -parallel
It works but is annoying. I expect I just need to modify the case/system/controlDict and continue running the case in parallel.
Does anyone have the same problem or I miss something?
Michael@UW is offline   Reply With Quote
Best practice for smooth restart in parallel run of OpenFOAM yek_irani OpenFOAM Running, Solving & CFD 9 August 9, 2023 12:19
Error running simpleFoam in parallel Yuby OpenFOAM Running, Solving & CFD 14 October 7, 2021 05:38
The problem when i use parallel computation for mesh deforming. Hiroaki Sumikawa OpenFOAM Running, Solving & CFD 0 November 20, 2018 03:58
Can not run OpenFOAM in parallel in clusters, help! ripperjack OpenFOAM Running, Solving & CFD 5 May 6, 2014 16:25
parallel Grief: BoundaryFields ok in single CPU but NOT in Parallel JR22 OpenFOAM Running, Solving & CFD 2 April 19, 2013 17:49
