Running a high Re low mach rhoPimpleFoam
Old   November 15, 2022, 14:56
Question Running a high Re low mach rhoPimpleFoam
CaptCrash is on a distinguished road
Hello everyone!
I am a long time reader, first time poster. I am trying to run a rhoPimpleFoam for a steady state high reynolds number low mach airfoil but running into a supersonic flow solution. Here are the pertinent simulation parameters
Chord (m): 10.85838
Re: 95,624,744
Angle of Attack (deg): 5
Uxyz (m/s): [128.1220, 11.20922, 0]
Uinf (m/s): 128.611
Minf (Mach): 0.378
Tinf (K): 288.15
Pinf (Pa): 101325
rho (kg/m^3): 1.225
Pr: 0.7323
Hf (j/kg): 2.8833272E5
Y+ target: 30
Turbulence Properties: RAS, kOmegaSST, I = 0.01%
k: 2.48E-4
nut: 1.2E-2
omega: 2.07E-2
I've attached as many of the files as possible to this string to help. I used gmsh for the mesh generation and those files are included as well to generate a full mesh which, after generating and saving the mesh in gmsh, can be converted using gmshToFoam <file_name.msh>. I considered running a normalized chord (1 meter) in water at 107.404m/s. The issue being this will be part of a series of test to generate CL/CD/CM plots up to the trans-sonic regime so I would like to capture those effects. Thank you very much in advance for your assistance.
CaptCrash is offline   Reply With Quote
Old   November 16, 2022, 19:07
Default Follow up information
The following information is what I calculated for the inflation layers. The grid is a C-H grid. I've included an image of the C-H grid, the computations for the inflation layers, and the checkMesh output. The C-H grid has has the following properties.
checkmeshreport.txt
Old   November 19, 2022, 14:45
I think one issue stems from the high aspect ratio mesh cells. I am using GMSH but I can not figure out how to generate an inflation layer and maintain a structured CH mesh. Every topic or example I've seen has been an inflation layer connected to an unstructured mesh. I used this video (slowed down to 25% playback):https://www.youtube.com/watch?v=bekRbU7rtZE as the basis for generating the mesh, except for the wake spacing. I tried using snappyHexMesh earlier in the process but the blender plugin doesnt seem to work on linux for some reason.
Thanks in advance for any help.
airfoil, high reynolds number, low mach, rhopimplefoam, supersonic
high Temperature shoot up and high mach flow. skdubey ANSYS 1 February 19, 2022 07:35
demarcation between high Re number and Low Re number pdewcfd Main CFD Forum 0 March 31, 2021 04:24
High Mach number flow Taendyr Main CFD Forum 8 November 29, 2020 08:15
Multiphase, high Mach simulations alexvaleije FLUENT 0 June 6, 2019 07:53
replacing of shock tube high pressure part with a boundary condition for low pressure immortality Main CFD Forum 0 May 2, 2013 14:30
