Supply either a patchName or a coupleGroup for patch Battery1Tab1In_fluid in region f
Old   November 13, 2022, 23:36
Default Supply either a patchName or a coupleGroup for patch Battery1Tab1In_fluid in region f
Ding Yan
batteryFoamer is on a distinguished road
Dear all,
I have a problem that has been a long time, but I can not still solve it.
It's that I modify the chatmultiRegionFoam and add the potential equation in this solver. When I set up the case, I need to add two special patches on the positive and negative tabs of the prismatic battery, one is the Battery1Tab1In for the influx of current, and Battery1Tab2Out for the outflux of battery, which are shown in the figure 1.
I use the topoSet and createBafflesDict to create these patches,
But finally, I get the errorhow to solve this problem)
--> FOAM FATAL ERROR:
Supply either a patchName or a coupleGroup for patch Battery1Tab1In_fluid in region fluid
From function const Foam::word& Foam::mappedPatchBase::samplePatch() const
in file mappedPatches/mappedPolyPatch/mappedPatchBaseI.H at line 65.
FOAM exiting
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 6
\\/ M anipulation |
FoamFile
version 2.0;
format ascii;
class dictionary;
object topoSetDict;
actions
// *********************battery region*********************
name battery1CellSet;
type cellSet;
action new;
source boxToCell;
sourceInfo
//box (0.005 0.011 0.012)(0.073 0.019 0.048);
box (0.016 0.011 0.012)(0.084 0.019 0.048);
// length: 68 8 36
name solid;
type cellZoneSet;
action new;
source setToCellZone;
sourceInfo
set battery1CellSet;
// *********************tab1 solid*********************
type cellSet;
action add;
source boxToCell;
sourceInfo
//box (0.0 0.013 0.018)(0.005 0.017 0.028);
box (0.011 0.013 0.018)(0.016 0.017 0.028);
name solid;
type cellZoneSet;
action add;
sourceInfo
// *********************tab2 solid*********************
type cellSet;
action add;
source boxToCell;
sourceInfo
//box (0.0 0.013 0.032)(0.005 0.017 0.042);
box (0.011 0.013 0.032)(0.016 0.017 0.042);
name solid;
type cellZoneSet;
action add;
sourceInfo
// *********************tab1 patch*********************
name Battery1Tab1FlowInSetFaceSet;
type faceSet;
action new;
source boxToFace;
sourceInfo
box (0.0109 0.013 0.018)(0.0111 0.017 0.028);
//box (-0.0009 0.013 0.032)(0.0001 0.017 0.042);
name Battery1Tab1FlowInSet;
type faceZoneSet;
action new;
source setToFaceZone;
sourceInfo
faceSet Battery1Tab1FlowInSetFaceSet;
// *********************tab2 patch*********************
name Battery1Tab2FlowOutSetFaceSet;
type faceSet;
action new;
source boxToFace;
sourceInfo
box (0.0109 0.013 0.032)(0.0111 0.017 0.042);
//box (-0.0009 0.013 0.018)(0.0001 0.017 0.028);
name Battery1Tab2FlowOutSet;
type faceZoneSet;
action new;
sourceInfo
faceSet Battery1Tab2FlowOutSetFaceSet;
// *********************Air region*********************
name AirCellSet;
type cellSet;
action new;
source cellToCell;
sourceInfo
set solid;
name AirCellSet;
type cellSet;
action invert;
name fluid;
type cellZoneSet;
action new;
sourceInfo
set AirCellSet;
batteryFoamer is offline   Reply With Quote
What exactly the Relaxation factor does? Raza Javed OpenFOAM Running, Solving & CFD 11 July 2, 2019 04:42
HeatSource BC to the whole region in chtMultiRegionHeater xsa OpenFOAM Running, Solving & CFD 3 November 7, 2016 06:07
[Commercial meshers] Using starToFoam clo OpenFOAM Meshing & Mesh Conversion 33 September 26, 2012 05:04
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
