useing reactingTwoPhaseEulerFoam to simulate solid dissolution
Old   November 11, 2022, 09:49
Default useing reactingTwoPhaseEulerFoam to simulate solid dissolution
fengzhou
1007809902 is on a distinguished road
I'm trying to simulate solid dissolved in liquid and then reacting in liquid phase, reactingTwoPhaseEulerFoam solver was used. However, I did not find a suitable masstransfer model to describe the behavior of solid dissolving. I think using interfaceComposition model in phaseProperties file can achieve this goal, but the saturation models of interfaceComposition model such as Antoine, ArdenBuck seem to be only applicable to gas-liquid systems rather than liquid-solid systems.
I would like to know where to set the saturated solubility of the solute, or if there are similar cases I can learn from, thank you!!!
1007809902 is offline   Reply With Quote
solid;dissolve;euler;
[CAD formats] Mesh for a solid described by parametric surfaces Align OpenFOAM Meshing & Mesh Conversion 1 August 24, 2016 05:37
How to simulate spherical solid particle immersed in fluid CFDapplication OpenFOAM Running, Solving & CFD 0 May 10, 2016 17:55
Structural analysis- bosy surface part from the solid part andreina Structural Mechanics 0 October 12, 2015 10:56
[swak4Foam] mass conservation of solid phase violated when using groovyBC with twoPhaseEulerFoam xpqiu OpenFOAM Community Contributions 8 June 17, 2015 03:08
Immersed solid, vs solid-fluid interaction to determine forces on a submerged solid amrbekhit CFX 0 January 8, 2015 17:39
