No thermal or hydraulic diffusion in reactingFoam |
Rep Power: 11 ![]() |
I am trying to do 2d asysimmetric simulations of fuel pyrolysis a flow reactor with hot wall and laminar gas flow using reactingFoam. So, I created a axisymmetric mesh of simple pipe.
First, I ran the case with no chemistry to make sure velocity and temperature distribution are fine by setting Code:
chemistry off; I also applied a constant temperature of ![]() ![]() I checked the results, and I noticed that there are not thermal or hydraulic boundaries are formed near the wall of the pipe, so heat does not diffuse from the hot wall to the gas! Is there anyway to capture laminar diffusion in reactingFoam? ![]() |
Any suggestions?
reactingfoam; diffusion |
No thermal or hydraulic diffusion in reactingFoam | adib_mohammad | Main CFD Forum | 0 | November 7, 2022 13:55 |
Thermal diffusion coefficient(about Soret effect) | sasenbb | FLUENT | 5 | December 22, 2020 22:04 |
Thermal diffusion coefficient empirical formula | Chris S | FLUENT | 6 | September 11, 2018 18:49 |
Moving mesh | Niklas Wikstrom (Wikstrom) | OpenFOAM Running, Solving & CFD | 122 | June 15, 2014 06:20 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
