Integration steps greater than maximum 1000
Old   November 1, 2022, 04:27
Question Integration steps greater than maximum 1000
mactone hsieh
mactone is on a distinguished road
Hi, FOAMers,
I encountered a problem on reactingFoam solving process.
There are two threads on this forum 1 & 2
The first thread shows changing the ODEcoeff solver might help. Tried with no luck.
I am using ode_pyJac (from DLBFoam) as chemistryType solver, seulex_LAPACK as odeCoeffs solver.
Running reactingFoam to solve a burner flame with PaSR combustion model, with maxCo 0.3, maxDeltaT 1e-5.
I tried changing the odeCoeff solver with other 11 solvers. No luck.
When I rerun the case, the Temperature and Composition min/max will be the same 4.9423e+307.
I also tried rerun from previous steps, it's the same result. "Integration steps greater than maximum 1000" right away. I need to roll back to the first step (0) to be able to run again.
I wondere if any one could show me a hint! Thank you.
mactone is offline   Reply With Quote
odesolver, reactingfoam
Integration steps greater than maximum!!! omid20110 OpenFOAM Running, Solving & CFD 8 November 16, 2022 09:07
Maximum Temperature greater than the boundary temperature sathwik718 STAR-CCM+ 3 May 19, 2014 18:05
how to increase maximum number iterations to > 1000? phsieh2005 OpenFOAM 6 September 25, 2011 18:02
Temperature greater than maximum range byanw81 STAR-CD 1 July 24, 2009 11:45
DPM: Particle Tracking Madhukar FLUENT 1 July 24, 2007 04:51
