West Midlands
Rep Power: 4 ![]() |
I have this model in OpenFOAM, and its been over a month i have trying to run it on supercomputer, however on my local machine it runs till 4 seconds in couple of weeks, however on supercomputer the simulation gets aborted within seconds, I am not sure the mistake i am making in this model, the log file reads as follows in the attachment, not sure what to do.
Anonymous
Rep Power: 3 ![]() |
I don't think your image provides enough information to determine the cause of the failure. In my experience (I have quite a bit of experience with failed cases), there's usually a line earlier in the file that says something like "FOAM FATAL ERROR" or "FOAM FATAL IO ERROR" with additional context. Can you look for a more specific description or upload your log file?
West Midlands
Here is the top of the log file, everytime it gives the same error i dont understand why
Anonymous
This seems more like an issue with how OpenFOAM is being run than a problem with the case itself. Are you requesting adequate resources for the job on the supercomputer? The number of tasks you request through the job scheduler must be consistent with the way you've set up your case (numberOfSubdomains for decomposePar, for example).
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch | gschaider | OpenFOAM Installation | 225 | August 25, 2015 19:43 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
OpenFOAM without MPI | kokizzu | OpenFOAM Installation | 4 | May 26, 2014 09:17 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
