Solid collapses in icoReactingMultiphaseInterFoam
Old   October 26, 2022, 05:42
Default Solid collapses in icoReactingMultiphaseInterFoam
Alczem is on a distinguished road
Hello everyone!
I am experimenting with icoReactingMultiphaseInterFoam to try and simulate the melting of a snowman made of ice surrounded by air, and with an incoming radiant flux from the top boundary to provide heat.
The issue is that as soon as the simulation starts, my snowman seems to collapse on itself, like a fluid would, even without any mass transfer. I think I defined the properties of the different phases properly and I can't figure out the issue. I tried to play with gravity and the simulation works fine without any gravity, so I must have defined the boundary conditions or the solid phase poorly.
Does someone have an idea? Thanks!
Here are some files that may be relevant
fvSolution.solvers
    "alpha.*"
        nAlphaCorr      1;
        nAlphaSubCycles 2;
        cAlphas         ((liquid and solid)  0
                    (liquid and gas)  1
                    (gas and solid)  0);
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance       1e-8;
        relTol          0;
phaseProperties (without melting):
type    massTransferMultiphaseSystem;
phases    (liquid gas solid);
liquid
    type            pureMovingPhaseModel;
solid
    type            pureStaticSolidPhaseModel;
gas
thermophysicalProperties.solid
thermoType
    type            heSolidThermo;
    mixture         pureMixture;
    transport       constIso;
    thermo          hConst;
    equationOfState rhoConst;
    specie          specie;
    energy          sensibleEnthalpy;
mixture
    specie
        nMoles          1;
        molWeight       18;
    equationOfState
        rho             1000;
    thermodynamics
        Cp              2093;
        Hf              0; //[J/Kg];
    transport
        kappa           2.22;
Alczem is offline   Reply With Quote
Old   October 26, 2022, 14:05
Krapf is on a distinguished road
Could you please upload the whole case?
Krapf is offline   Reply With Quote
ice, icoreacting, melting, multiphase
Solid combustion problem.... godspeedsam FLUENT 3 May 24, 2022 05:29
Error - Solar absorber - Solar Thermal Radiation MichaelK CFX 12 September 1, 2016 06:15
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
Moving solid problem Mudblood FLUENT 0 June 10, 2010 13:11
How to calculate density of solid phase zhou Main CFD Forum 0 December 17, 1999 20:06
