October 24, 2022, 07:31 |
Multiple flow rate outlets - simpleFoam
Quentin d'Avout
Rep Power: 9 |
Hi all,
I'm setting up a pipe flow sim with two outlets and one inlet, a Tee in-between, incompressible liquid, simpleFoam, komegaSST turbulence, good y+30 mesh, numerical schemes similar to the pipeCyclic tutorial. I have to impose volumetric flow at the two outlets and pressure at the inlet. patchSummary: Code:
Valid fields: volScalarField nut volVectorField U volScalarField k volScalarField p volScalarField omega group : wall scalar nut nutkWallFunction scalar k kqRWallFunction scalar p zeroGradient scalar omega omegaWallFunction vector U noSlip patch : in1 scalar nut calculated scalar k zeroGradient scalar p totalPressure scalar omega zeroGradient vector U pressureInletOutletVelocity patch : out2 patch : out1 scalar nut calculated scalar k inletOutlet scalar p zeroGradient scalar omega inletOutlet vector U flowRateOutletVelocity group : processor scalar nut processor scalar k processor scalar p processor scalar omega processor vector U processor Is two fixed outgoing flow rates the problem? Anyone has ever run something similar? Thanks in advance for any help. Q |
flowrateoutletvelocity, pipe flow, simplefoam |
Annulus Flow Through Multiple Inlets and Outlets, Fluent (Student) | Mecha | FLUENT | 1 | July 9, 2021 04:19 |
Match Pressure Inlet/Outlet Boundary Condition Mass Flow Rate | MSchneid | Fluent UDF and Scheme Programming | 3 | February 23, 2019 07:00 |
DPM total mass flow rate | yow | FLUENT | 0 | July 17, 2015 13:01 |
how to set BC for compressible flow target mass flow rate | foolboy007 | FLUENT | 1 | April 4, 2012 04:24 |
Multiple flow outlets | rahul | FLUENT | 2 | October 28, 2002 03:03 |
