p, U, etc. are not appearing in paraView when I run my case |
October 16, 2022, 16:00 |
Alan w
Rep Power: 6 |
This is a follow-up to my post regarding the method to get rid of edges around the domain. I was charged up with finding a way to do it, but my balloon deflated when I tried to run the case.
In paraView, the mesh shows up, but none of the flow parameters such as p and U. The pulldown just shows color stuff. And then I get a paraview error message as shown in the attached image. It says that there are problems in my boundary conditions, but I copied them verbatim from the motorBike tutorial, so I know that there must be some other problem. But what is it? I think the answer must be something simple that I will be embarrassed about, but I am still stumped. Help! |
October 16, 2022, 18:23 |
Rep Power: 21 |
This error occurs if paraview can't find a boundary condition for all fields. The issue is that you definied custom variables for example internalField kOmega and used includeEtc to abbreviate some of them etc...now once you solve your case these are automatically added from the solver for all solution time steps...the issue is that your custom definitions in the zero folder can't be read by paraview. Either fully write out all of them or skip the zero folder when reading in the case.
Or simply open the case in paraview and switch to the next time step. The error will still be there but once you are past the 0 folder everything should work. |
October 20, 2022, 13:46 |
p and U are not showing in paraView, but they don't cycle
Alan w
Rep Power: 6 |
Thank you again Bloerb, for your help!
I am still working the p & U not showing in paraView problem, with some progress, but it's still a mess. In my previous post, I had mentioned this paraView error: 'unsupported directive includeEtc.' Also shown in the message was: 'expected number, string or (, found pressure.' In this particular case, openFoam is not recognizing '#includeEtc "caseDicts/setConstraintTypes"' for some reason. So my first attempt was to add ' export PATH=~/OpenFOAM/OpenFOAM-8/etc/caseDicts/:$PATH' into my .bashrc file. It ddn't work. In a search, I found comments from you, responding to a similar problem (sorry, can't find it now). In your reply, you said that the contents of the setConstraintTypes file could be added to each boundary condition in /0. This I did, and the openFoam complaints went away! Here is the p file in 0: Code:
FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; //internalField uniform $pressure; internalField uniform 0; boundaryField { //- Set patchGroups for constraint patches //#includeEtc "caseDicts/setConstraintTypes" inlet { type zeroGradient; } outlet { type fixedValue; value $internalField; } ground { type zeroGradient; } frontier { type slip; } wing { type zeroGradient; } cyclic { type cyclic; } cyclicAMI { type cyclicAMI; } cyclicACMI { type cyclicACMI; value $internalField; } cyclicSlip { type cyclicSlip; } conformalCoupled { type conformalCoupled; } empty { type empty; } cyclicRepeatAMI { type cyclicRepeatAMI; } processor { type processor; value $internalField; } processorCyclic { type processorCyclic; value $internalField; } symmetryPlane { type symmetryPlane; } symmetry { type symmetry; } wedge { type wedge; } } In this particular case, why are these changes necessary? Who knows? They seem to be a clumsy measure for a problem that shouldn't be there. So after all these changes to satisfy the paraView gripes, here is what happens: p and U are now showing, but when I pick the 'run' triangle at the top, they do not increment, but just stay at the initial condition. The attached image just stays unchanged. However! I am tracking the forces in this case, and in postProcessing, I see this output: Code:
# Force coefficients # liftDir : (0.000000e+00 0.000000e+00 1.000000e+00) # dragDir : (1.000000e+00 0.000000e+00 0.000000e+00) # pitchAxis : (0.000000e+00 1.000000e+00 0.000000e+00) # magUInf : 2.000000e+01 # lRef : 1.420000e+00 # Aref : 7.500000e-01 # CofR : (7.200000e-01 0.000000e+00 0.000000e+00) # Time Cm Cd Cl Cl(f) Cl(r) 0 -3.110116e-06 3.447695e-04 -8.214199e-06 -7.217215e-06 -9.969833e-07 1 -1.182160e-01 1.696657e-01 -2.737468e-01 -2.550894e-01 -1.865738e-02 2 -6.849332e-02 8.714572e-02 -1.539839e-01 -1.454853e-01 -8.498621e-03 3 -4.967265e-02 3.516505e-02 -1.091358e-01 -1.042406e-01 -4.895274e-03 4 -3.744147e-02 2.635948e-02 -8.024028e-02 -7.756161e-02 -2.678671e-03 Can you help me understand this snafu? |
October 20, 2022, 14:59 |
#4 | |
Rep Power: 21 |
Nevertheless... If you do have a writeInterval set so that an actual time step folder is written each time they should be read when opening paraview. You might have to use the refresh button in paraview or restart it once the results are there. |
October 22, 2022, 17:13 |
Solved this problem, but now OpenFoam won't recognize my velocity!
Alan w
Rep Power: 6 |
Hi Bloerb,
Thanks again; I am fortunate to receive help from knowledgeable people such as yourself. I solved my #include files problem by taking the mesh, along with the flow parameters, and plugging them into an older case that actually worked properly. Now it was okay, and I didn't have to include all of those caseDicts in the BC files. Note to self: If you have a case where everything works properly, DO NOT UNDER ANY CIRCUMSTANCES, delete it, but rather place it in an archive for safe keeping. But, whereas the older case gave proper results for flow past a body, when I made the substitutions, I got very strange results for the U flowfield, as seen in the attached image. I kept all the BC file structures the same, and despite my specifying the velocity as 40 m/sec., it looks as though the flow is just meandering around at some slow value. Regarding the p results, they just stay the same and do not update. Also attached is an image showing the domain definition. This domain came from salome, and included the definitions for inlet, outlet, ground, wing and frontier. Here are my boundary condition files, in the hopes that obvious mistakes can be seen: for k: Code:
#include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; //internalField uniform $turbulentKE; internalField uniform 0.24; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" //- Define inlet conditions #include "include/fixedInlet" outlet { type inletOutlet; inletValue $internalField; value $internalField; } ground { type kqRWallFunction; value $internalField; } wing { type kqRWallFunction; value $internalField; } frontier { type slip; } } Code:
dimensions [0 2 -1 0 0 0 0]; internalField uniform 0; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" inlet { type calculated; value uniform 0; } outlet { type calculated; value uniform 0; } ground { type nutkWallFunction; value uniform 0; } wing { type nutkWallFunction; value uniform 0; } frontier { type slip; } } Code:
#include "include/initialConditions" dimensions [0 0 -1 0 0 0 0]; //internalField uniform $turbulentOmega; internalField uniform 1.78; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" #include "include/fixedInlet" outlet { type inletOutlet; inletValue $internalField; value $internalField; } ground { type omegaWallFunction; value $internalField; } wing { type omegaWallFunction; value $internalField; } frontier { type slip; } } Code:
#include "include/initialConditions" dimensions [0 2 -2 0 0 0 0]; //internalField uniform $pressure; internalField uniform 0; boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" inlet { type zeroGradient; } outlet { type fixedValue; value $internalField; } ground { type zeroGradient; } wing { type zeroGradient; } frontier { type slip; } } Code:
#include "include/initialConditions" dimensions [0 1 -1 0 0 0 0]; //internalField uniform $flowVelocity; internalField uniform (40 0 0); boundaryField { //- Set patchGroups for constraint patches #includeEtc "caseDicts/setConstraintTypes" #include "include/fixedInlet" outlet { type inletOutlet; inletValue uniform (0 0 0); value $internalField; } ground { type fixedValue; value $internalField; } frontier { type slip; } wing { type noSlip; } } Any idea what is going on with my U field? Again, sincere thanks for all the help you have given me. |
icoFoam won't run while Paraview is running | MikeHersee | OpenFOAM Running, Solving & CFD | 2 | January 6, 2015 06:06 |
[OpenFOAM] ParaView 4.10 and OpenFOAM 2.3.0 Multiregion and decomposed case | romant | ParaView | 3 | April 7, 2014 16:42 |
DPMFoam case worked perfectly in the first run but crashes in every subsequent run!! | ansubru | OpenFOAM Running, Solving & CFD | 6 | March 17, 2014 05:27 |
Trying to run a benchmark case with simpleFoam | spsb | OpenFOAM | 3 | February 24, 2012 10:07 |
Paraview crash after opening OF case | gfilip | OpenFOAM Installation | 4 | October 14, 2009 15:46 |
