October 14, 2022, 02:42 |
Initialize denseParticleFoam
Marcus Voigt
Rep Power: 4 |
Hey Guys,
I am struggling to setup a particle laden flow in openFoam. Initialy I started with a steady state case and transfered to unsteady one. (Switching from simpleFoam to pimpleFoam and using the simpleFoam results as 0) But now I am facing two problems: 1. I cant initialize denseParticleFoam with pimpleFoam results, as the fields are not the same 2. If I try to initialize directly the unsteady case with denseParticleFoam my bounding epsilon and then my bounding k are exploding thus crashing everything. I tried more robust numeric schemes. I tried starting with low initial velocities but this issue always crashes my simulation The geometry is a pipe with 1 inlet and 2 outlets. I have attached the BCs, fvSchemes and fvSolutions. Thank you for you help Best regards epsilon.air.txt U.air.txt p.txt nut.air.txt k.air.txt |
April 21, 2024, 21:39 |
Rep Power: 6 |
Hi Marcus,
Did you find a solution to this problem? I am encountering a problem with the error below. I hope you or anyone with the knowledge can help resolve it. failed lookup of Uc (objectRegistry region0) available objects of type volScalarField: 5(nu mu.air p alpha.air rho.air) |
June 13, 2024, 07:30 |
Marcus Voigt
Rep Power: 4 |
the solution for the exploding k and epsilon was a bad mesh. When I remeshed with snappy it worked. Second "failed lookup of Uc" tells you that veloicty of the continous phase does not exists. This problem could be because your Uc-Text files stills has U written inside as the object and not Uc. Best regards Marcus |
dense particles, epsilon bounds, openfoam 9., turbulence |
loading fluent data and turbo initialize in CFD post | shohag | FLUENT | 0 | June 29, 2020 20:26 |
loading fluent data and turbo initialize in CFD post | shohag | ANSYS | 0 | June 29, 2020 20:25 |
loading fluent data and turbo initialize in CFD post | shohag | ANSYS | 0 | June 29, 2020 20:23 |
initialize from data file | robboflea | FLUENT | 4 | June 20, 2018 09:41 |
Initialize the field using another simpler turbolence model | ArathoN | OpenFOAM Running, Solving & CFD | 6 | March 2, 2014 21:55 |
