How to set boundaries for chtMultiregionFoam
Old   October 12, 2022, 12:50
Default How to set boundaries for chtMultiregionFoam
Nico
Hr_kules is on a distinguished road
Hey guys,
i want to compare different geometries with the same flow statistics ranging from a specified mass flow from 0.02 kg/s to 0.06 kg/s and examine heat transfer differences of different features of the geometry as well as the pressure drop.
How can i set the boundaries, that i can specify the mass flow and a given pressure, so i can calculate the pressure drop? The thermal boundary conditions are clear and working.
Thanks!
Hr_kules is offline   Reply With Quote
Possible bug with stitchMesh and cyclics in OpenFoam Jack001 OpenFOAM Pre-Processing 0 May 21, 2016 09:00
[mesh manipulation] Problem with using createPatchDict to define cyclic boundaries kaszt OpenFOAM Meshing & Mesh Conversion 0 April 1, 2016 22:18
set BC mass-flow-inlet via UDF and via GUI perform different result sawa25 FLUENT 1 February 25, 2015 01:51
[General] 2 datas on one plot Akuji ParaView 46 December 1, 2013 15:06
Help with GNUPlot Renato. Main CFD Forum 6 June 6, 2007 20:51
