An error with parallelization in foam extend
Old   October 11, 2022, 10:23
Default An error with parallelization in foam extend
hbulus is on a distinguished road
Hello everyone, i have fe40 and fe41 at the same machine. When i run a tutorial case with parallel processors, i get this error at below:
It looks like opal_init failed for some reason; your parallel process is
likely to abort. There are many reasons that a parallel process can
fail during opal_init; some of which are due to configuration or
environment problems. This failure appears to be an internal failure;
here's some additional information (which may only be relevant to an
Open MPI developer):
opal_shmem_base_select failed
--> Returned value -1 instead of OPAL_SUCCESS
Can anyone help me ?
hbulus is offline   Reply With Quote
error with reactingFoam BakedAlmonds OpenFOAM Running, Solving & CFD 4 June 22, 2016 03:21
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 10:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 15:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 15:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 09:19
