ridiculous results with phaseScalarTransport in interFoam
Old   October 11, 2022, 04:08
Default ridiculous results with phaseScalarTransport in interFoam
Thomas Shi
ThomasLong is on a distinguished road
Hi Foamers,
I am really struggling with simulating the contaminant transport in water by using the new function object phaseScalarTransport in interFoam. I have read some threads on this topic in the forum and been trying to modifiy the controlDict in my own case, but the results are quite ridiculous, which is incomprehensible for me.
Here is my codes of phaseScalarTransport function and the results of the simulation in 5s :
  scalarTransport
    type            phaseScalarTransport;
    libs            ("libsolverFunctionObjects.so");
    enabled         true;
    writeControl    writeTime;
    writeInterval   1;
    rho             rho;
    phase           alpha.water;
    field           s.water;
    diffusion       viscosity;
    alphal          1;
    alphat          1;
    nut             nut;
    resetOnStartUp  no;
ThomasLong is offline   Reply With Quote
Old   October 12, 2022, 03:31
Thomas Shi
Anyone ? Please give me some suggestions.
Old   October 12, 2022, 06:32
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
Hi Thomas,
My first guess would be about the discretisation scheme you use for the convection of the scalar. You will need some stabilization on that term typically. It looks like you now have too little of that and then you can get unbounded results.
Cheers,
Tom
tomf is offline   Reply With Quote
Old   October 13, 2022, 04:22
Thomas Shi
Thank you very much for your reply! I will have a try.
Old   January 8, 2023, 08:49
Dylan James
dylan_OF is on a distinguished road
Hi Thomas,
I have the same problem at present. Have you solved your problem?
Could you please share your experience?
Thanks in advance!
dylan_OF is offline   Reply With Quote
Old   January 10, 2023, 10:31
Dylan James
Originally Posted by dylan_OF View Post
Hi Thomas,
Thanks in advance!
I have solved the problem.
The fvOptions should be removed from system/controlDict--functions--sTransport.
interfoam, scalar transport
interFoam - different results compared to others in a micro T-junction Mary_F OpenFOAM Running, Solving & CFD 1 July 28, 2023 16:13
interFoam - Not getting better performance on parallel run ctvanrees OpenFOAM Running, Solving & CFD 16 August 31, 2021 09:30
Rising Bubble Test Case Using interFoam: Unrealistic Results?! farazarbabi OpenFOAM Running, Solving & CFD 21 May 7, 2021 09:45
Problem: Very long "write" time (~2h-3h) for results and transient results Shawn_A CFX 16 April 12, 2016 21:49
Microchannel flow interfoam. (results far away from theoritical answers) Saideep OpenFOAM Running, Solving & CFD 1 June 24, 2015 13:09
