Using solids4Foam applied to FSI problems - OF9 - symmetryPlane issue
Old   October 7, 2022, 09:22
Default Using solids4Foam applied to FSI problems - OF9 - symmetryPlane issue
Santa Catarina
awgomes is on a distinguished road
I am using solids4foam with the OF9 version of OF foundation to run simple FSI cases. I have done some case tutorials referring to fluid, but referring to solid, the 'symmetryPlane' patch is not recognized. Does anyone know about this problem? If it is better to use another version of OpenFOAM, I would also like to know
--> FOAM FATAL IO ERROR:
patch type 'symmetryPlane' not constraint type 'symmetry'
for patch symmetry of field D in file "/home/awgomes/OpenFOAM/awgomes-9/run/tutorials/fluidSolidInteraction/beamInCrossFlow/0/solid/D"
file: /home/awgomes/OpenFOAM/awgomes-9/run/tutorials/fluidSolidInteraction/beamInCrossFlow/0/solid/D/boundaryField/symmetry from line 38 to line 40.
From function Foam::symmetryFvPatchField<Type>::symmetryFvPatchF ield(const Foam::fvPatch&, const Foam:: DimensionedField<Type, Foam::volMesh>&, const Foam::dictionary&) [with Type = Foam::Vector<double>]
in file /opt/openfoam9/src/finiteVolume/lnInclude/symmetryFvPatchField.C at line 56.
FOAM exiting
awgomes is offline   Reply With Quote
[ICEM] Problems with coedge curves and surfaces tommymoose ANSYS Meshing & Geometry 6 December 1, 2020 12:12
Divergent temperature in chtMultiRegion(Simple)Foam akrasemann OpenFOAM Running, Solving & CFD 13 March 24, 2014 03:54
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 13:13
Problems with circular shapes in FSI simulations kezman ANSYS 0 September 15, 2009 10:36
how to extend FSI 2D codes to 3D, need advises abouziar Main CFD Forum 1 May 30, 2008 05:08
