How to override boundary condition type to zeroGradient
Old   September 30, 2022, 18:08
Default How to override boundary condition type to zeroGradient
xuegy is on a distinguished road
Hello all,
I need to override the following boundary condition to "zeroGradient":
sidewall
     	type            calculated;
        value           nonuniform List<scalar>
1914
(l�(��K���MTOd8���o?����>��^QɐѠ>�A�*Gļ��^]q�ˇ��(�Z�m���p�^?��㳾p�^^|A���PR�9���$
and I've tried these ways:
1. Manually edit the file. It works, but I want to do it automatically.
2. Use setExprBoundaryFields utility
pattern
    field   N1;
    expressions
            patch   sidewall;
            target  type;
            expression zeroGradient;
    keepPatches  true;
gives me
Processing field N1
--> FOAM FATAL IO ERROR: (openfoam-2112)
Wrong token type - expected string, found on line 25: word 'zeroGradient'
file: system/setExprBoundaryFieldsDict.pattern.expressions.expression at line 26.
    From Foam::Istream& Foam::operator>>(Foam::Istream&, Foam::string&)
    in file primitives/strings/string/stringIO.C at line 53.
FOAM exiting
3. Use funkySetBoundaryField utility
Stress
    field N1;
    expressions
            patchName  sidewall;
            target     type;
gives me (basically the same error)
Part: Stress working on field N1
file: system/funkySetBoundaryDict.Stress.expressions.expression at line 25.
FOAM exiting
From here, https://develop.openfoam.com/Develop.../-/issues/1762
upcasting of word to string/fileName was added August-2019.
So is that a bug? or are these utilities simply can't change the boundary type?
Many thanks.
xuegy is offline   Reply With Quote
Old   October 3, 2022, 04:51
Yann
Yann will become famous soon enoughYann will become famous soon enough
It sounds like a job for changeDictionary: https://www.openfoam.com/documentati...ictionary.html
Cheers,
Yann
Yann is offline   Reply With Quote
Wind turbine simulation Saturn CFX 60 July 17, 2024 06:45
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 07:20
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[swak4Foam] Air Conditioned room groovyBC Sebaj OpenFOAM Community Contributions 7 October 31, 2012 15:16
Pressure instability with rhoSimpleFoam daniel_mills OpenFOAM Running, Solving & CFD 44 February 17, 2011 18:08
