September 29, 2022, 06:50 |
Big changes in pressure interface. interFOAM
heru
Rep Power: 10 |
I am solving a cylinder (D=1) submerged in water and Re = 40 000. I have solved this "simple" problem with other code with good results. In openFOAM I get really high values in pressure forces. I guess that the problem is the pressure bubbles that are created by the interface (see attached figs). Those bubbles lead to a big error. If the cylinder is close to the free surface the error increase since the pressure distribution is changed. Mesh and time step are OK (same that literature). I have tried different schemes and solvers for pressure and always I get the same error. Also the free surface seems to be OK. Does anyone know how can I avoid those problems in the free surface? |
Pressure fields in FOAM, p field, total pressure, etc. | Tobi | OpenFOAM Post-Processing | 9 | March 25, 2022 02:33 |
Basic Nozzle-Expander Design | karmavatar | CFX | 20 | March 20, 2016 09:44 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 05:05 |
Replace periodic by inlet-outlet pair | lego | CFX | 3 | November 5, 2002 21:09 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 14:19 |
