Mass conservation problems with chtMultiRegionTwoPhaseEulerFoam
Old   September 28, 2022, 14:55
Default Mass conservation problems with chtMultiRegionTwoPhaseEulerFoam
JS1970 is on a distinguished road
Dear Foamers,
I've been using openfoam for more than 2 years and tried an ambitious step.
I've based my case on tutorials\heatTransfer\chtMultiRegionTwoPhaseEuler Foam\solidQuenching2D case. But I have converted it to 3D with some additional points.
It's a roll mill quenching simulation using 1/4 of the geometry (+ tank). Until I was running it in still water, there were no problems. They arrised when I've started using a forced convection in the tank.
I've tried several approaches, but stick to "velocity" (mass volume flow rate) inlet + outlet. Means, all the mass that goes out, comes in again. That may be the source of the problem. I've used (for better stability) and time based table of mass flow rate until 5 seconds
I've compacted the whole case information and attached it to the post. May be useful also for others, looking for a similar situation. Sorry, I was unable to attach the zip file because it's larger than the allowed size. But request it to me and I will try to share it thru wetransfer or something like this.
The problem:
- after some seconds the tank starts to fill up completely until the water level reaches the top boundary condition.
The image shows the integral of the alpha field over the time.
Last edited by JS1970; September 28, 2022 at 15:19. Reason: add animated gif to attachments
JS1970 is offline   Reply With Quote
Old   September 28, 2022, 15:09
Default Attachment thru wetransfer
https://wetransfer.com/downloads/c7c...8180736/aad04b
chtmultiregionfoam, mass conservation, quenching
scalarTransportFoam mass conservation failure with irregular mesh bou OpenFOAM Running, Solving & CFD 0 January 10, 2022 05:42
Mass Rate or Vol Rate Conservation CFD89 CFX 1 April 22, 2021 20:10
Mass conservation in VOF steady state deepak7937 FLUENT 0 November 21, 2011 07:58
Mass conservation in COMSOL Diego COMSOL 1 December 27, 2010 06:14
Mass flux - Axisymmetric problems. JSM FLUENT 0 May 3, 2007 00:56
