Square cylinder non-symmetric results?
Old   September 27, 2022, 16:02
Question Square cylinder non-symmetric results?
Max Vorstadt
jet_engine is on a distinguished road
Hi all,
I am using buoyantBoussinesqPimpleFoam to solve a simple case with a square cylinder but although the velocity contours seem to be OK (Karman vortex street forming past the square cylinder, the pressure contours neither look symmetrical nor right.
I am attaching the important bits of the initial conditions set for U and p_rgh:
dimensions [0 1 -1 0 0 0 0];
internalField uniform (19.68 0. 0.);
boundaryField
        outlet
                type inletOutlet;
                inletValue   uniform (19.68 0. 0.);
                value        uniform (19.68 0. 0.);
        upperLower
                type symmetry;
        inlet
                type fixedValue;
        symPlane
                type symmetry;
        cylinder
                type fixedValue;
                value    uniform (0. 0. 0.);
dimensions [0 2 -2 0 0 0 0];
internalField uniform 0.;
boundaryField
        outlet
                type            fixedValue;
                value           uniform 0.;
        upperLower
                type symmetry;
        inlet
                type zeroGradient;
        symPlane
                type symmetry;
        cylinder
                type zeroGradient;
I'm also setting the kinematic viscosity to nu = 0.000656 m^2/s and since the square cylinder's side is 0.01 m long and u_inf = 19.68 m/s, Re = 300.
I tried different mesh densities (some of them quite fine) and all of them seem to behave in the same way, there's a spot over the square cylinder or below it where the pressure contours behave in a strange manner.
What am I doing wrong? Are the Boundary Conditions OK? Could it be the mesh? I'm a bit lost.
(I'm using this solver as I want to do a slip study, but in this case there was no slip and yet the results look this strange).
Thank you very much in advance.
jet_engine is offline   Reply With Quote
buoyantboussinesq, divergence, mesh, pressure, symmetry
Strouhal Number of a square cylinder not matching saugatshr4 FLUENT 1 April 10, 2020 04:38
HELP! Regards to Square Cylinder! Quek ANSYS 0 February 3, 2016 02:51
[blockMesh] square cylinder obstacle fferroni OpenFOAM Meshing & Mesh Conversion 2 May 26, 2012 05:48
Undergrad Civil Student: need help with simulating 2d flow past a square cylinder Karim Byasse Main CFD Forum 0 May 5, 2012 23:58
LES of a square cylinder gfilip OpenFOAM Running, Solving & CFD 1 June 24, 2010 13:33
