September 19, 2022, 05:19 |
fluid flow through a rough channel
ahmad
hi guys.
I want to model fluid flow through a rough channel. it's for a laminar incompressible flow. its geometry is like a cube, but its inner surfaces have roughness. roughness is like natural topographies and rock surfaces. one direction of the cube is the inlet, the other is the outlet and I want 3d modeling. geometry size is like 100*100*0.1 mm which tutorials do you suggest? which way do you think is better for meshing? (Salome, snappyHexMesh, other meshing software) |
incompressible flow, mesh 3d, rough wall, solver, tutorial |
Intuition for why flow follows convex surfaces | lopp | Main CFD Forum | 47 | February 1, 2022 14:14 |
Fluid flow in rectangular channel | Nagaraj N | FLUENT | 0 | October 12, 2021 01:25 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 18:38 |
flow depth in channel | mahdi1 | FLOW-3D | 5 | May 30, 2013 06:28 |
Modeling the mixing of air and kerosene in a flow channel | StefanG | CFX | 3 | June 11, 2012 21:21 |
