Inadequate results on OF9 for a case using interFoam
Old   September 15, 2022, 10:46
Default Inadequate results on OF9 for a case using interFoam
srikanth
srikanthdeti is on a distinguished road
Dear Foamers,
I'm trying to use OF9 for my simulations on multiphase flows using interFoam solver by considering dynamic mesh refinement. Earlier, I used OF8 for the same simulation by letting the setup as it is with the same grid size & same refinement level. But, OF9 visual results are quite disappointing. The contour plots of the field in OF9 is showing some unexpected spikes on the surfaces. Whereas OF8 results are fairly smooth.
I'm attaching the images captured at the same time instance(i.e., 0.0008s) of both versions' results with an iso-surface value of 0.1 and the case zip file. I request your help to solve this issue.
Thanks in advance.
srikanthdeti is offline   Reply With Quote
dynamic mesh adaption, interfoam interdymfoam, openfoam 8, openfoam 9, simulation
interFoam vs. simpleFoam channel flow comparison DanM OpenFOAM Running, Solving & CFD 12 January 31, 2020 16:26
FOAM-extend's interFoam giving different results compared to OpenFOAM's Santiago OpenFOAM Running, Solving & CFD 0 August 27, 2019 05:24
Different results between pisoFoam and interFoam Stephen Waite OpenFOAM Running, Solving & CFD 3 July 28, 2019 17:42
2D flow around a circular cylinder case with interFoam solver shuoxue OpenFOAM Running, Solving & CFD 0 August 31, 2013 06:04
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 13:24
