September 13, 2022, 06:03 |
interFoam BC for open water
Eric Segalerba
Rep Power: 5 |
Hello everyone!
I'm trying to simulate the flow exiting a pipe placed around 3 meters under the sea level. The case is 2D but I'm having some problems with the boundary conditions for the "sea". So far I set: U inlet -> flowRateInletVelocity outlet -> inletOutletVelocity p inlet -> fixedFluxPressure outlet -> zeroGradient alpha inlet -> fixedValue ... value 1 outlet -> variableHeightFlowRate With those B.Cs the simulation diverges and I can't figure out what to change to make it works... Do you have any guess or tip? Thank you in advance |
September 13, 2022, 20:04 |
Joachim Herb
Rep Power: 22 |
You do not specify the pressure with your boundary conditions. Somewhere you need some kind of fixedValue boundary condition for p (or actually for p_rgh).
September 14, 2022, 06:41 |
Eric Segalerba
Rep Power: 5 |
Hi and thank you for your quick answer! Actually after some tests I was able to make it work by splitting the outlet patch in two and imposing flowRateOutletVelocity in the water patch!
boundaries condition, interfoam, sea |
Water level drop at outlet InterFoam solver | IngmarScholte | OpenFOAM Running, Solving & CFD | 1 | December 17, 2020 14:35 |
simulating water tank using interfoam | dpoly | OpenFOAM Running, Solving & CFD | 0 | March 26, 2020 17:18 |
Problem condensation/ evaporation (condensate water vapor) | bigfoot47 | FLUENT | 0 | October 21, 2019 09:07 |
No liquid water exist in my Fuel Cell simulation | fatchang | FLUENT | 19 | October 15, 2018 15:27 |
(interfoam) shear stress at water air interface ! | openfoam1 | OpenFOAM | 11 | October 27, 2014 04:59 |
