September 11, 2022, 03:56 |
Error while running SimpleFOAM in parallel
#1 | |
Muhammad Rafi Sudrajat
I running a simulation using simpleFOAM in parallel, but I got an error like this
#!/bin/sh cd ${0%/*} || exit 1 # Run from this directory # Source tutorial run functions . $WM_PROJECT_DIR/bin/tools/RunFunctions runApplication surfaceFeatures runApplication blockMesh runApplication -a foamDictionary -entry "method" -set "hierarchical" system/decomposeParDict runApplication decomposePar runApplication -a foamDictionary -entry "method" -set "ptscotch" system/decomposeParDict runParallel snappyHexMesh runParallel $(getApplication) runApplication reconstructParMesh runApplication reconstructPar https://drive.google.com/file/d/1lnF...ew?usp=sharing I don't understand why this error happens, can you tell me where is my fault and how can I solve this problem? Best regards Thank you |
September 15, 2022, 17:50 |
Rep Power: 12 |
Its saying you aren't writing your p value to each folder. Try running snappyhexmesh with the -overwrite option on. Also try decomposePar with the copyzero option.
commands: runApplication decomposePar -copyZero runParallel snappyHexMesh -overwrite |
September 26, 2022, 02:06 |
Thank you for the answer, but I want to see the simulation result of every time step, so I cannot user -overwrite option. Can you figure out another solution?
Best Regards |
error, incompressible, parallel, simplefoam |
OF 2.0.1 parallel running problems | moser_r | OpenFOAM Running, Solving & CFD | 9 | July 27, 2022 04:15 |
parallel simpleFoam requires 0/s ; serial solution works | sral | OpenFOAM Running, Solving & CFD | 5 | October 17, 2019 09:55 |
running iocFoam in parrallel | tenichols19 | OpenFOAM Running, Solving & CFD | 6 | October 7, 2019 05:44 |
Running parallel case after parallel meshing with snappyHexMesh? | Adam Persson | OpenFOAM Running, Solving & CFD | 0 | August 31, 2015 23:04 |
Problem in Running OpenFoam in Parallel | himanshu28 | OpenFOAM Running, Solving & CFD | 1 | July 11, 2013 10:19 |
