Umut
Rep Power: 15 ![]() |
Dear FOAMers,
I installed pyFoam (and swak4Foam) successfully (hopefully) and using/testing them for the first time. I run hotRoom tutorial using pyFoamPlotRunner.py an it run as expected without an error. (residuals were plotted and time directories were written) My question is: After I type "pyFoam" and press tab, auto complete options are shown, however when I type "pyFoamPlotRunner.py --" and press tab, options (--clear --progress etc.) are not auto completed. Is it expected or does it mean I did sth wrong with the installation or setting the environment variables? Any help is appreciated Cheers Umut Note: I installed python3.8, pip, and run the below command: sudo update-alternatives --install /usr/bin/python python /usr/bin/python3 10 When I type "which python pip" the results are as follows /usr/bin/python /home/owner/.local/bin/pip (I added /home/owner/.local/bin to PATH in .bashrc before using pyFoam) I'm using OF-v2206 on Ubuntu 20.04.4 LTS (windows11 wsl) |
pyfoam, tab completion |
Problems with PyFoam and batch file! | alfogianco | OpenFOAM Running, Solving & CFD | 0 | January 5, 2022 08:57 |
[ICEM] FEA Solve Options tab | arkane07 | ANSYS Meshing & Geometry | 4 | March 6, 2021 06:33 |
Possible Missing Tab Completion in OFv1712? | HakikiCanakkaleli | OpenFOAM Bugs | 19 | July 12, 2018 06:27 |
[ICEM] FEA Solve Options tab | narthurm | ANSYS Meshing & Geometry | 6 | December 13, 2017 13:18 |
Advanced Options Tab for flow simulation | Roose28 | CFX | 1 | March 21, 2016 17:19 |
