Is writeInterval independent form file updating time?
Old   September 7, 2022, 09:05
Default Is writeInterval independent form file updating time?
Dohyun Kim
Dohyun is on a distinguished road
Unless I stop the simulation, is the actual writeInterval always based on startTime?
I am trying to write data only at specific times:
(10.3, 10.55, 10.8, 11.05, ... , 12.3).
I used a 'file updating function object' method.
But the results I've got was:
(10.3, 10.5, 10.75, 11.0, ... , 12.25).
Changing the writeInterval seem to be worked properly, but the time I've changed the interval did not affected the actual saved times.
I've used the settings shown below.
Isn't it proper for my purpose?
controlDict:
startFrom       startTime;
startTime       10.3;
stopAt          endTime;
endTime         12.3;
deltaT          0.0002;
writeControl    adjustableRunTime;
writeInterval   0.25;
purgeWrite      0;
writeFormat     binary;
writePrecision  8;
writeCompression on;
timeFormat      general;
timePrecision   10;
runTimeModifiable yes;
adjustTimeStep  no;
maxCo           0.2;
functions
    #includeFunc vorticity
    #includeFunc CourantNo
    fileUpdate_writeInterval
        type              timeActivatedFileUpdate;
        libs              ("libutilityFunctionObjects.so");
        writeControl      timeStep;
        writeInterval     1;
        fileToUpdate      "$FOAM_CASE/system/controlDict";
        timeVsFile
            (10.3    "$FOAM_CASE/system/controlDict_new")
controlDict_new:
startTime       10.3;
stopAt          endTime;
endTime         12.3;
deltaT          0.0002;
writeInterval   0.25;
purgeWrite      0;
writeFormat     binary;
writePrecision  8;
timeFormat      general;
timePrecision   10;
adjustTimeStep  no;
maxCo           0.2;
functions
        writeInterval     1;
        timeVsFile
Dohyun is offline   Reply With Quote
Using PengRobinsonGas EoS with sprayFoam Jabo OpenFOAM Running, Solving & CFD 36 July 16, 2024 04:52
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
[OpenFOAM.org] Compile OF 2.3 on Mac OS X .... the patch gschaider OpenFOAM Installation 225 August 25, 2015 20:43
Version 15 on Mac OS X gschaider OpenFOAM Installation 113 December 2, 2009 11:23
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 18:51
