chtMultiRegionFoam, conservation and interface T |
September 7, 2022, 06:34 |
Gonglin Li
Hello, everyone! I recently learned the chtMultiRegionFoam and tried to do some redevelopment of models in this solver. I notice that in most cases, the iteration was non-existent, and the fluid regions and solid regions are solved one by one.
In openfoam-2206 Code:
for (int oCorr=0; oCorr<nOuterCorr; ++oCorr) { const bool finalIter = (oCorr == nOuterCorr-1); forAll(fluidRegions, i) { #include "setRegionFluidFields.H" #include "readFluidMultiRegionPIMPLEControls.H" #include "solveFluid.H" } forAll(solidRegions, i) { #include "setRegionSolidFields.H" #include "readSolidMultiRegionPIMPLEControls.H" #include "solveSolid.H" } ···· } Besides, checking in boundary condition code showed different interface temperature: A case with two regions, the initial temperatures were 300 K and 400 K, output interface temperature with code "Info <<····" HTML Code:
deltaT = 0.1 Region: fluid Courant Number mean: 0 max: 0 Region: metal Diffusion Number mean: 0.00411523 max: 0.0164609 deltaT = 0.11999 Time = 0.11999 Solving for fluid region fluid ··· interface temp: 400 ··· ··· Solving for solid region metal ··· interface temp: 300 I understand how the interface temperature was solved, and the results showed good conservation on energy. But discussion above bring the final question: *In theory or real world, a interface temperature should only have a single value at any time. How could the solver remains good conservation on energy with two temperature value on interface? In other words, the chtMultiRegionFoam could have good conservation on energy without iteration of interface temperature, which makes me confuse. Any opinion or suggestion would be helpful, any more details could be upload if needed. |
chtmultiregionfoam, conservation |
Wind turbine simulation | Saturn | CFX | 60 | July 17, 2024 05:45 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
volume conservation and accurate interface shape | Prosper | OpenFOAM Running, Solving & CFD | 9 | May 14, 2015 09:47 |
Frozen Rotor 1:1 Mesh Connection | pharley | CFX | 5 | January 31, 2013 16:15 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
