Floating point exception and increasing corruant numbers |
September 5, 2022, 13:55 |
Rep Power: 4 |
I am attempting to set up my first real simulation after doing several tutorials.
Currently I have successfully created a mesh for my system. In the end I will need a fairly complicated system but currently I am just attempting to get the simulation to run and am planning to add in features one at a time. Currently I am attempting to simulate incompressible flow in a region that is adjacent to a spinning shaft. I can get the simulation to run successfully if I don't have the wall rotating but if I add any conditions that would cause motion in the region my corruant number quickly grows, and then after a point I get the following error. Time = 0.005s Courant Number mean: 0.0642621 max: 1.20394 #0 Foam::error:rintStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::symGaussSeidelSmoother::smooth(Foam::word const&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::Field<double> const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, unsigned char, int) at ??:? #4 Foam::symGaussSeidelSmoother::smooth(Foam::Field<d ouble>&, Foam::Field<double> const&, unsigned char, int) const at ??:? #5 Foam::smoothSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:? #6 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/icoFoam" #7 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/icoFoam" #8 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/icoFoam" #9 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/icoFoam" #10 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #11 ? in "/opt/openfoam10/platforms/linux64GccDPInt32Opt/bin/icoFoam" Floating point exception (core dumped) I assume that my simulation is set up incorrectly. Does anyone have experience with similar errors? This is my U file at 0: /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class volVectorField; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { symPlane { type symmetryPlane; } hotInlet { type zeroGradient; } coldInlet { type zeroGradient; //value uniform (0 0 -.001); } circOutlet { type zeroGradient; } axialOutlet { type zeroGradient; } rotatingWall { // type noSlip; type rotatingWallVelocity; origin (0 0 -20); axis (0 1 0); omega 0.1; } staticWall { type noSlip; } defaultFaces { type empty; } } my controlDict: /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1; deltaT .001; writeControl runTime; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; } /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application icoFoam; startFrom startTime; startTime 0; stopAt endTime; endTime 1; deltaT .001; writeControl runTime; writeInterval 1; purgeWrite 0; writeFormat ascii; writePrecision 6; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; } my fvSchemes: /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object fvSchemes; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ddtSchemes { default steadyState; } gradSchemes { default leastSquares; } divSchemes { default none; div(phi,U) Gauss linearUpwind grad(U); //div(div(phi,U)) Gauss linear; } laplacianSchemes { default Gauss linear corrected; } interpolationSchemes { default linear; } snGradSchemes { default corrected; } and my fvSolutions: /*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 10 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.05; } // pFinal // { // $p; // relTol 0; // } U { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-05; relTol 0; } } PISO { nCorrectors 2; nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; } I have an image of the mesh but am having trouble uploading it to this post because it asks for a url, does anyone know a good way to do this? I suspect that the issue is linked to the fact that the corruant number increases every time step until it becomes larger than 1. I have also tried simply defining a slow flow from one of the inlets and that causes a similar error. I tried a few divergence schemes as well but that just changed when the error occurred. I am hoping that I have committed some common rookie mistake so I figured I would ask for help. |
beginner, courant, error |
Floating Point Exception Error | nyox | FLUENT | 11 | November 30, 2018 12:31 |
icoFoam floating point exception (8) | leizhao512 | OpenFOAM Running, Solving & CFD | 7 | November 1, 2018 11:43 |
FATAL: floating point exception (AMG divergence) | KeganLeckness | FLUENT | 1 | December 2, 2015 11:10 |
Help with solving floating point exception crash. | rendagar | Main CFD Forum | 1 | March 26, 2014 07:34 |
Floating point error and divergence detected | aannjj | FLUENT | 0 | July 2, 2013 03:44 |
