Lee Model, evaporation and heat transfer
Like Tree1Likes
Old   September 23, 2022, 03:27
Al
aliyah. is on a distinguished road
Originally Posted by Alczem View Post
Hey
Thanks for the helpful answer, I tried to compile a new solver myIcoReactingMultiphaseInterFoam but during wmake I get a new error (see attached picture). I fear there is much more to do to get it working
I changed the files for the lib according to your indications (it compiles properly)
Here is my options for the new solver :
phaseSystem = $(LIB_SRC)/phaseSystemModels/multiphaseInter
EXE_INC = \
    -I${phaseSystem}/phasesSystem/lnInclude \
    -I${phaseSystem}/compressibleMultiPhaseTurbulenceModels/lnInclude \
    -I$(LIB_SRC)/finiteVolume/lnInclude \
    -I$(LIB_SRC)/fvOptions/lnInclude\
    -I$(LIB_SRC)/meshTools/lnInclude \
    -I$(LIB_SRC)/sampling/lnInclude \
    -I$(LIB_SRC)/dynamicFvMesh/lnInclude \
    -I$(LIB_SRC)/transportModels/compressible/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/turbulenceModels/lnInclude \
    -I$(LIB_SRC)/TurbulenceModels/compressible/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/radiation/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/basic/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/specie/lnInclude \
    -I$(LIB_SRC)/thermophysicalModels/reactionThermo/lnInclude \
    -I$(FOAM_SOLVERS)/multiphase/interFoam
EXE_LIBS = \
    -L$(FOAM_USER_LIBBIN) \
    -lmyIncompressibleMultiphaseSystems \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -ldynamicFvMesh \
    -lturbulenceModels \
    -lcompressibleTurbulenceModels \
    -lthermoTools \
    -lcompressibleTransportModels \
    -lradiationModels \
    -lfluidThermophysicalModels \
    -lsolidThermo \
    -lsolidSpecie \
    -ltwoPhaseProperties \
    -llaserDTRM \
    -lincompressibleMultiphaseSystems \
    -lcompressibleMultiPhaseTurbulenceModels
As always thanks for your time!
Hey, I am just guessing, but are you sure in the EXE_INC = \ part of the Make/options you add the right address. The address for the default library should be changed to the address for the new library in the EXE_INC = \ part.
aliyah. is offline   Reply With Quote
Old   September 23, 2022, 06:44
Alczem is on a distinguished road
Hey!
I made the changes as you suggested, but the same error happens.
Here is the latest version of the options of the custom solver:
EXE_INC = \
    -I$(FOAM_USER_LIBBIN) \
    -I/home/bonin/Documents/customLeeModel/lnInclude \
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -ldynamicFvMesh \
    -lthermoTools \
    -lradiationModels \
    -lsolidThermo \
    -lsolidSpecie \
    -llaserDTRM \
I am definitely out of my depth here
Alczem is offline   Reply With Quote
Old   December 16, 2022, 08:25
guo
gsy0826 is on a distinguished road
Have you solved it? I also want to change it to calculate the multicomponent to multicomponent do you have some good ideas?
gsy0826 is offline   Reply With Quote
Old   December 16, 2022, 09:00
Smile
  #24
guo
Hey!
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -ldynamicFvMesh \
    -lthermoTools \
    -lradiationModels \
    -lsolidThermo \
    -lsolidSpecie \
    -llaserDTRM \
hello
i guess that you do not link the multiphaseInter into this solver, just like the origin version of icoReactingMultiphaseInterFoam, it links to the src/phaseSystem but you changed phaseSystem you don't link in there
Old   December 16, 2022, 09:21
Originally Posted by gsy0826 View Post
hello
Hey!
Unfortunately I could not spend more time to figure it out, sorry. If you manage to make some progress, do not hesitate to report it here or on a new thread, I for one would be glad to know!
Old   October 31, 2023, 08:46
Ant Yang
Ant_Yang is on a distinguished road
Hey
EXE_INC = \
EXE_LIBS = \
    -lfiniteVolume \
    -lfvOptions \
    -lmeshTools \
    -lsampling \
    -ldynamicFvMesh \
    -lthermoTools \
    -lradiationModels \
    -lsolidThermo \
    -lsolidSpecie \
    -llaserDTRM \
Hello Alczem,
When I tried to add a new combination, I met the same problem as yours. Do you have found a solution?
BR,
Ant_
Ant_Yang is offline   Reply With Quote
evaporation, lee model
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Evaporation-Condensation in a porous zone (Heat transfer problem) maximilian-1 Fluent Multiphase 1 August 22, 2018 10:42
mass flow in is not equal to mass flow out saii CFX 12 March 19, 2018 06:21
Multiphase flow - incorrect velocity on inlet Mike_Tom CFX 6 September 29, 2016 02:27
Two-Phase Buoyant Flow Issue Miguel Baritto CFX 4 August 31, 2006 13:02
