XiFoam error: Failing on multiple meshes
Old   August 30, 2022, 04:31
Default XiFoam error: Failing on multiple meshes
Dilshan Casseer
casseer15 is on a distinguished road
I'm trying to simulate the combustion of a simple case of H2 combustion with air in a square container of 12m x 3m x 3m. I set the ignition at the middle, and tried to simulate a case with o.75 equivalence ratio with inhomogenous method. The mesh is a entirely hexagonal mesh. LES with KEqn SGS model is used. I use pimple with 4 iteration steps. Solver is GAMG. I tried PCG as well, but got same result.
I tried different meshes (40mm, 20mm, 30mm) but always I get an error and calculation stops after about 0.02 seconds. At this time I noticed that b goes t negative values, which is impossible. I have used limitedlinear01 as the div scheme for b, so it should essentially limit b within 0 and 1, but it doesn't seem to happen here.
I always get the below error.
can anyone please shed any light on what the error can be.
#0 Foam::error:rintStack(Foam::Ostream&) at ??:?
#1 Foam::sigFpe::sigHandler(int) at ??:?
#2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
#3 double Foam::sumProd<double>(Foam::UList<double> const&, Foam::UList<double> const&) at ??:?
#4 Foam::PBiCGStab::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#5 Foam::GAMGSolver::solveCoarsestLevel(Foam::Field<d ouble>&, Foam::Field<double> const&) const at ??:?
#6 Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMa trix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#7 Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#8 Foam::fvMatrix<double>::solveSegregated(Foam::dict ionary const&) at ??:?
#9 Foam::fvMatrix<double>::solve(Foam::dictionary const&) in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/XiFoam"
#10 Foam::fvMatrix<double>::solve() in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/XiFoam"
#11 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/XiFoam"
#12 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#13 ? in "/opt/openfoam9/platforms/linux64GccDPInt32Opt/bin/XiFoam"
I can't wrap my head around what is happening and has been stuck here for a couple of weeks, so any help is greatly appreciated.
casseer15 is offline   Reply With Quote
Old   August 30, 2022, 21:34
Dilshan Casseer
Anyone can give me some idea on this please?
Old   March 2, 2023, 00:39
Sarah
Sarah13 is on a distinguished road
Hi
Did you find any insights on this issue? I am also getting negative values of b, specifically in case of 3D simulations, that doesn't seem to happen with 2D cases.
Sarah13 is offline   Reply With Quote
combustion, hydrogen, xifoam
Preserve meshes in Fluent parametric run hwerner2014 FLUENT 2 February 28, 2022 17:29
[mesh manipulation] Importing Multiple Meshes thomasnwalshiii OpenFOAM Meshing & Mesh Conversion 18 December 19, 2015 19:57
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
Large 3D tetrahedral meshes Aldo Bonfiglioli Main CFD Forum 4 August 27, 1999 04:33
