Define fixed flow rate fan? Cannot cyclic and fixed value? |
August 26, 2022, 23:39 |
ff
Rep Power: 16 |
Hello Foamers,
I need a help to define a fixed flow rate fan (equal to fixed velocity). In normal Fan, we define a cyclic plane, in U and T field just use cyclic, and pressure uses a fan BC which based on fixedJump ( cyclic jump), and fan BC will based on PU curve and patch velocity to tune pressure. However, in fixed rate fan, it needs to keep the velocity same on master and slave side. So I want to do U with fixedValue e.g. (1 0 0) on both master and slave side, p and T use cyclic. But openfoam not happy to mix patch and cyclic. It will shows following ERROR: --> FOAM FATAL IO ERROR: (openfoam-2012) inconsistent patch and patchField types for patch type cyclic and patchField type fixedValue Could anyone give any suggestions? Cheers, |
Appling a fan inside the domain/duct | Tobi | OpenFOAM Running, Solving & CFD | 3 | April 12, 2022 06:57 |
Duct flow with two fans - SimpleFOAM stops after first iteration | Kryoleiche | OpenFOAM Running, Solving & CFD | 0 | September 14, 2021 05:40 |
Channel Flow with Constant Mass Flow Rate | huzafa | OpenFOAM Running, Solving & CFD | 0 | August 1, 2018 11:31 |
Fixed flow rate with cyclic BC | Marc-Aurele | OpenFOAM | 1 | July 27, 2015 15:03 |
Artificial jump in turbulent quantities across cyclic patch in slice of 360 deg flow | natrask | OpenFOAM Running, Solving & CFD | 0 | March 26, 2009 11:21 |
