Local Time Stepping / icoReactingMultiphaseInterFoam |
August 26, 2022, 09:09 |
Rep Power: 6 |
Hello!
I am trying to figure out the proper way to use Local Time Stepping with icoReactingMultiphaseInterFoam. My simulation includes two fluids and mass transfer (Lee model) from one phase to the other. The mesh has 2M cells (cfMesh) and the computation time seems quite long, so I am interested in using LTS to speed things up since I am interested in a steady state. I read about STLS and CoEuler, which my case accepts (as it seems to be running) but I am not sure about the settings. For instance, can we use several outer iterations (in PIMPLE) while using LTS? If anyone has any experience with LTS I would gladly hear more about this Thanks for the help! fvSolution Code:
solvers { ".*(rho|rhoFinal)" { solver PCG; preconditioner DIC; tolerance 1e-05; relTol 0.1; } "alpha.*" { solver PBiCG; preconditioner DILU; tolerance 1e-08; relTol 0.0; cAlphas ((N2 and gas) 1); nAlphaCorr 1; nAlphaSubCycles 3; MULESCorr true; // Compressiion factor for species in each alpha phase // NOTE: It should be similar to cAlpha cYi 1; } "pcorr.*" { solver PCG; preconditioner DIC; tolerance 1e-5; relTol 0; } "(epsilon.*|k.*)" { solver smoothSolver; smoother symGaussSeidel; tolerance 1e-8; relTol 0.1; }; "U.*" { solver PBiCGStab; preconditioner DILU; tolerance 1e-8; relTol 0.1; } "T.*" { solver PBiCGStab; preconditioner DILU; tolerance 1e-08; relTol 0.05; residualAlpha 1e-5; } p_rgh { solver GAMG; smoother GaussSeidel; tolerance 1e-6; relTol 0.05 ; nPreSweeps 0; nPostSweeps 2; cacheAgglomeration true; nCellsInCoarsestLevel 20; agglomerator faceAreaPair; mergeLevels 1; maxIter 50; }; p_rghFinal { $p_rgh; relTol 0; }; "Xvapour_N2.gas.*" { solver PBiCGStab; preconditioner DILU; tolerance 1e-08; relTol 0.0; } } PIMPLE { momentumPredictor true; nOuterCorrectors 1; nCorrectors 1; nNonOrthogonalCorrectors 1; turbOnFinalIterOnly false; residualControl { "(p_rgh)" { relTol 0; tolerance 0.001; } "(k|epsilon|omega)" { relTol 0; tolerance 0.001; } "(T)" { relTol 0; tolerance 0.0001; } } } relaxationFactors { fields { } equations { "(k|epsilon)" 0.7; "(h.*|e.*)" 0.5 p_rgh 0.5; T 0.5; ".*Final" 1; } } Code:
ddtSchemes { //default CoEuler phi maxCo 1; default SLTS phi rho 0.7; //default steadyState; } gradSchemes { default cellLimited Gauss linear 1; grad(p) Gauss linear 1; //grad(U) cellMDLimited Gauss linear 0.333; //default Gauss linear; } divSchemes { div(rhoPhi,U) Gauss linearUpwind default; "div\(phi,alpha.*\)" Gauss vanLeer; "div\(phir,alpha.*\)" Gauss linear; "div\(Yiphir,alpha.*\)" Gauss linear; "div\(phi,.*\.gas.*\)" Gauss vanLeer; div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear; div(phi,T) Gauss linearUpwind default; div(rhoPhi,epsilon) bounded Gauss upwind; div(rhoPhi,k) bounded Gauss upwind; div((alpha.gas*U)) Gauss linear; div((alpha.liquid*U)) Gauss linear; div((p*U)) Gauss linear; } laplacianSchemes { default Gauss linear limited 1; } interpolationSchemes { default linear; } snGradSchemes { default limited 1; } fluxRequired { default no; p_rgh ; alpha.gas ; alpha.N2 ; Xvapour_N2.gas ; } |
Convergence problem of OF | WUYing | OpenFOAM Running, Solving & CFD | 2 | September 20, 2021 11:09 |
Setting up Lid driven Cavity Benchmark with 1M cells for multiple cores | puneet336 | OpenFOAM Running, Solving & CFD | 11 | April 7, 2019 01:58 |
Micro Scale Pore, icoFoam | gooya_kabir | OpenFOAM Running, Solving & CFD | 2 | November 2, 2013 14:58 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 04:34 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 15:09 |
