August 25, 2022, 09:56 |
CO2 and Age of Air
Ben Simpson
Rep Power: 7 |
I have a simple natural ventilation model using OpenFOAM v8. It uses the buoyantSimpleFoam and k-omega SST. The aim of the model is to predict the ventilation performance. Part of this requires sampling an internally generated contaminant (CO2) and the age of the air. The model appears to be running and converging correctly but when I calculate the ventilation performance metrics using the predicted CO2 and age of air I am getting unrealistic metric values. I have included the main files used for generating and sampling the CO2 and age of air. Can anyone see any mistakes or issues with the way I am modelling these two fields? I have also attached a compressed version of my model if that helps. Thank you for any assistance. Regards, Ben controlDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | Model: VE_Practice | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object controlDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // application buoyantSimpleFoam; startFrom latestTime; startTime 0; stopAt endTime; endTime 5000; deltaT 1; writeControl timeStep; writeInterval 1000; purgeWrite 3; writeFormat ascii; writePrecision 8; writeCompression off; timeFormat general; timePrecision 6; runTimeModifiable true; /*libs ( "libOpenFOAM.so" "libsimpleSwakFunctionObjects.so" "libswakFunctionObjects.so" "libgroovyBC.so" );*/ functions { #include "surfaces" #include "surfaces2" CO2 { type scalarTransport; libs ("libsolverFunctionObjects.so"); writeControl timeStep; writeInterval 1; active true; autoSchemes false; nCorr 0; resetOnStartUp false; field CO2; fvOptions { generalSource { type semiImplicitSource; active true; selectionMode cellZone; cellZone spaceZone; volumeMode absolute; sources { CO2 { explicit 1; implicit 0; } } } } } comfortAnalysis { type comfort; libs ("libfieldFunctionObjects.so"); metabolicRate 1.2; clothing 0.7; extWork 0.0; executeControl writeTime; writeControl writeTime; } AoA { type scalarTransport; libs ("libutilityFunctionObjects.so"); enabled true; writeControl writeTime; log yes; nCorr 1; field AoA; active true; autoSchemes false; resetOnStartUp false; DT 1e-5; nCorr 0; fvOptions { IncrementTime { type semiImplicitSource; active true; selectionMode all; volumeMode specific; sources { AoA { explicit 1; implicit 0; } } } } } fieldMinMax { type fieldMinMax; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; //writeInterval 1; //mode magnitude; fields ( U p T rho CO2 AoA); } breathingZoneAverages { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType cellZone; name breathingZone; operation volAverage; fields ( T CO2 U PMV PPD AoA ); } breathingZoneValuesAvg { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType cellZone; name breathingZone; operation average; fields ( T CO2 U PMV PPD AoA ); } breathingZoneValuesSum { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType cellZone; name breathingZone; operation sum; fields ( T CO2 U PMV PPD AoA ); } spaceVolAverage { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType cellZone; name spaceZone; operation volAverage; fields ( T CO2 U AoA ); } spaceAverage { type volFieldValue; libs ("libfieldFunctionObjects.so"); log true; writeControl writeTime; writeFields true; regionType cellZone; name spaceZone; operation average; fields ( T CO2 U AoA ); } residuals { type residuals; functionObjectLibs ("libutilityFunctionObjects.so"); enabled true; writeControl timeStep; writeInterval 1; fields ( p_rgh U k omega CO2 e AoA ); } probes { type probes; libs ("libsampling.so"); writeControl timeStep; writeInterval 1; fields ( p_rgh U T CO2 k omega AoA ); probeLocations ( (1.6 3.1 2) //convergence point Occ1 (3.1 3.1 2) //convergence point Center (4.6 3.1 2) //convergence point Occ2 ); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | Model: VE_Practice | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "system"; object fvSolution; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // solvers { p_rgh { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.01; } "(U|T|CO2|e|k|omega|AoA)" { solver PBiCGStab; preconditioner DILU; tolerance 1e-05; relTol 0.1; } G { $p_rgh; tolerance 1e-05; relTol 0.1; } } SIMPLE { nNonOrthogonalCorrectors 0; pRefCell 0; pRefValue 0; residualControl { p_rgh 1e-2; U 1e-5; CO2 1e-4; T 1e-2; G 1e-3; e 1e-2; // possibly check turbulence fields "(k|omega)" 1e-3; } } relaxationFactors { fields { rho 1.0; p_rgh 0.9; } equations { U 0.1; CO2 0.3; T 0.5; e 0.5; "(k|R)" 0.7; P 0.8; G 0.7; omega 0.7; AoA 0.4; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object thermophysicalProperties; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // thermoType { type heRhoThermo; mixture pureMixture; transport const; thermo eConst; equationOfState Boussinesq; specie specie; energy sensibleInternalEnergy; } mixture { specie { molWeight 28.9; } equationOfState { rho0 1; T0 300; beta 3e-03; } thermodynamics { Cv 712; Hf 0; } transport { mu 1e-05; Pr 0.7; } } CO2 { specie { molWeight 44.01; } thermodynamics { Tlow 200; Thigh 5000; Tcommon 1000; highCpCoeffs ( 4.45362 0.00314017 -1.27841e-06 2.394e-10 -1.66903e-14 -48967 -0.955396 ); lowCpCoeffs ( 2.27572 0.00992207 -1.04091e-05 6.86669e-09 -2.11728e-12 -48373.1 10.1885 ); } transport { As 1.67212e-06; Ts 170.672; } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object CO2; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 0 0 0 0 0]; internalField uniform 0; boundaryField { "xmin|xmax|ymin|ymax||zmax_north|zmax_south" { type inletOutlet; inletValue $internalField; value $internalField; } "zmin|Ceiling|Floor|East_Wall|North_Wall|South_Wall|West_Wall|Computer|Person|zmax_ceiling|North_Window|South_Window" { type zeroGradient; } #includeEtc "caseDicts/setConstraintTypes" } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class volScalarField; location "0"; object AoA; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [0 0 1 0 0 0 0]; internalField uniform 0; boundaryField { "xmin|xmax|ymin|ymax|zmax_north|zmax_south" { type fixedValue; value uniform 0; } "zmin|Ceiling|Floor|East_Wall|North_Wall|South_Wall|West_Wall|Computer|Person|zmax_ceiling|North_Window|South_Window" { type zeroGradient; } #includeEtc "caseDicts/setConstraintTypes" } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1812 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ surfaces { type surfaces; libs ("libsampling.so"); writeControl writeTime; surfaceFormat raw; fields (U T CO2 AoA); interpolationScheme cell; surfaces ( NorthSlice { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (0 6.15 0); normal (0 1 0); } interpolate false; } SouthSlice { type cuttingPlane; planeType pointAndNormal; pointAndNormalDict { point (0 0.05 0); normal (0 1 0); } interpolate false; } ); } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: v1906 | | \\ / A nd | Web: www.OpenFOAM.com | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object topoSetDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // actions ( { name brZoneCells; type cellSet; action new; source boxToCell; sourceInfo { box (0.7 0.7 0.175) (5.5 5.5 1.9); } } { name breathingZone; type cellZoneSet; action new; source setToCellZone; sourceInfo { set brZoneCells; } } { name spaceCells; type cellSet; action new; source boxToCell; sourceInfo { box (0.1 0.1 0.1) (6.1 6.1 3.1); } } { name spaceZone; type cellZoneSet; action new; source setToCellZone; sourceInfo { set spaceCells; } } ); // ************************************************************************* // |
September 16, 2022, 07:08 |
Any thoughts?
Ben Simpson
Rep Power: 7 |
Anyone have any advice on this?
age of air, buoyantsimplefoam, contaminant, k-omega sst |
Air change effectiveness in a naturally ventilated building | kingjewel1 | FLUENT | 0 | November 30, 2015 16:30 |
fluent air flow and co2 mix species transport BC cabin | e.m.sabry | Fluent Multiphase | 0 | August 29, 2015 10:08 |
Air Exhalation in Humans | saisanthoshm88 | Main CFD Forum | 1 | January 30, 2012 18:14 |
tracer experiment for age of air | Tad | CFX | 1 | October 26, 2003 23:55 |
